Question about Konica Minolta magicolor 2400 Laser Printer
Konica Minolta 2400W Error Message
Hi All:
I have an issue with my Konica Minolta 2400. After cleaning the printer and reinstalling the toners back into the printer, I'm not getting an error message "Paper Jam at Transfer Roller." Does anyone know what I can do to get rid of this and get my printer working again?
There is NO paper jam and nothing out of place that would make this printer malfunction. I'm guessing this has to do with something funky with this printer, which I've been reading about.
My toners are brand new, and my drum still indicates 48% remaining.
Thanks all.
Ken
  • Anonymous Apr 18, 2009
    I have the same problem - replaced the drum unit - the error light still blinks - cannot find the black plastic flags. Pls help. Magicolor 2400W
    s123002
  • Anonymous Mar 18, 2014
    I GET AN ERROR MESSAGE TO REPLACE WASTE TONER
Remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
I have tons of problems with out printer aswell.
I have done several thing to fix a problem:
I restart the system connected to the printer, if this does not work try cleaning the gold metal detectors on the cartridges, if this does not work try uninstalling your printer and reinstalling it again.
Posted on Jun 10, 2008
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Where can I purchase a replacement fuser for konica minolta magicolor 2400w
You could buy it from :-
http://cgi.ebay.com/Konica-Minolta-Magicolor-2400-2400W-2430DL-2450-Fuser_W0QQitemZ180400879568QQcmdZViewItemQQptZPrinter_Accessories?hash=item2a00baf7d0
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 05, 2010 | Konica Minolta magicolor 2400 Laser...
How to specify the appropriate media type in the printer driver with the Konica Minolta 2400W
Go to printer properties -> Printing Preference -> Paper -> Media Type
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 13, 2009 | Konica Minolta magicolor 2400 Laser...
Replaced drum error light blinking
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Apr 14, 2009 | Konica Minolta magicolor 2400 Laser...
Error light
What kind of error....blinking light which lights are blinking..or is it a code 17h or something like that.....please clarify for me. thank you....whytfang. In the mean time you might take all of the cartridges out and make sure they are in correctly and none are damaged...and then clean the circuit boards and the reading board under the cartridges, then reinstall them and turn the printer back on...if not fixed try again and take care with the reading board...it is delicate...and the chips should be blown clean with pressurized air...like the canned spray used to clean keyboards or other delicate computer components. Try this in the meantime and send me the other info...good luck.
Jan 28, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta 2400w toners problem
My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
Dec 28, 2007 | Konica Minolta magicolor 2430 DL Laser...
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
2,329 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
