Question about Mitsubishi Televison & Video
Have a big screen turn it on and will stay on for about 5 seconds and then automatically turns off
  • Mitsubishi Master
  • 8,617 Answers
Need the model number in order to help you diagnose any possible cause to the problem youre having
Posted on May 23, 2008
I have a sony big screen blinking 5 times black screen...tv will only stay on 10 seconds and cutoff
I will need the model number from the rear cover to assist with the 5 blink error code.
Jul 29, 2011 | Sony Televison & Video
I have a Mitsubishi medallion 65 and it keeps turning off,
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WS-65411 65" Rear Projection...
I have a Mitsubishi 65" Big Screen TV (WS-65909). I cannot turn it on. When I press the power button, the "Timer" light stays on for about 3 seconds and then turns off and nothing happens. TV does not...
tO KNOW WHAT THE PROBLEM IS YOU HAVE TO DO THE SELF-CHECK that this model has.
After you turn it on and the power light goes off:
On the front of the TV press and hold both Menu and Input (or device) TOGETHER FOR AT LEAST 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light will blink an error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means. 2,2 is most common and the least expensive to fix.
If this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
sd tech
Nov 09, 2009 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Help with my big screen mitsubishi ws65869 tv
my screen is a right blue with no picture although I have sound it reads "tuner out"
Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
