Televison & Video Logo
Posted on Sep 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv standby - Televison & Video
Level 3:
  • Televison & ... Master 17,130 Answers
  • Posted on Sep 26, 2010
Level 3:
Answers
17130
Questions
0
Helped
3634873
Points
52372
Possible that the mainbaord is faulty, the output driver is short or a high voltage component is short.
Since the model is not specified , you will have to check the mother board for errors as your SMPS is working but check if the secondary fuse has gone off in the high voltage section of the SMPS.
Luxor tv flashing standby light
The flashing standby light on your Luxor TV can indicate several things, including:
  1. Power supply issues: If the TV is not receiving proper power, the standby light will flash.
  2. Malfunctioning hardware: A malfunctioning component in the TV such as the power supply, main board, or backlight system can cause the standby light to flash.
  3. Overheating: If the TV is overheating, it will go into protection mode and the standby light will flash.
  4. Software issues: A software glitch can also cause the TV to display a flashing standby light.
If the flashing standby light persists, it's best to unplug the TV, wait a few minutes, and then plug it back in. If the problem persists, you may need to contact the manufacturer or a professional repair service for further assistance.
How do I stop tv going on standby
hi Shaun.
How do I get my TV out of standby mode? Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.31 Mar 2015
How to Troubleshoot a TV in Standby ' Techwalla.com
https://www.techwalla.com/articles/how-to-troubleshoot-a-tv-in-standby Search for: How do I get my TV out of standby mode?
How do stop tv going on standby Google Search
2answers
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
I need the code number of tv to enable me to use sky remote control
Please try 0863 for Hyundai Televisions To program your Sky remote control using the 4 digit code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter 0863
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Please keep me posted.
Thanks.
Lor04
9helpful
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
6helpful
3answers
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
3helpful
Hitachi CLE984
The code you need is 0145
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
