Question about Mitsubishi WD-52525 52" Rear Projection HDTV
ANALOG/DIGITAL BOARD Just replaced the a/d board as recommended by the repair department.It was a simple process of removing the old and installing the new.Was extremely careful in reinstalling all cables as they were very clearly marked,installing the board in its proper position,plugged in the cable turned on the power.The only thing I have are a clicking of a on/off sound from the power supply,and the status light on the front flashing orange.The dvd ,which played with the old card,does not now play with the new card.Any ideas?I have reset the TV with the reset in the front.Any help would be greatly appreciated
  • Work It Jun 05, 2008
    My tv is doing the same thing, when turned on it make a click sound and the timer light is flasking green. Any ideas. Please Help!
Eat ur mom!! XD
Posted on Jun 05, 2008
How can I replace the fuel neck?
The fuel neck is attached to the fuel tank using a hose connection and clamps. The other end where the fuel enters is attached to the body using small bolts. You will have to look up inside the panel area to see these bolts. The fuel neck may be extremely diffucult to loosen/remove from the hose connection at the tank as years of weather/elements will cause the hose connecting the two to become hard and will not want to come apart. Although a fairly simple repair, there will be a moderate level of diffuculty seperating the old filler pipe to install a new one
Mar 10, 2016 | 1996 Chevrolet Blazer
Replace hard drive?
If you're asking how it's a very simple process and you can find many instructional videos on YouTube. You just need to buy a compatable drive, open your computer, disconnect the drive cable from the old hard drive, remove the screws holding the old drive in place and reverse the process to install the new one. You'll need to copy your old data over using an appropriate copy cable first if your old drive isn't dead or re-install an operating system and your files after the upgrade.
Nov 07, 2014 | Computers & Internet
No power unplugged set did not help tv 4 mos old thx
First of all you should properly check the electrical outlet on the wall for power using a voltmeter or a plug in reading lamp to ensure that it is not just a tripped breaker on your home's main electrical panel.
If that is not the case, then normally this is indicative of a faulty power supply circuit inside your TV.
Since your TV is only 4 months old, you should definitely try to return it to your place of purchase for a refund, exchange, or no cost warranty repair.
If your warranty is expired or returning it is not an option, then you may have to repair it yourself if you want to avoid paying a repair shop to do it.
The easiest way to test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one.
You can find a replacement circuit board on Ebay by searching for your TV's model number.
Here is a link to one currently available for about $70 plus shipping:
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
One other relatively simple / cheap thing you can check is to see if there is a fuse fitted on your set.
Some models will have a fuse holder compartment accessible from the rear of the set right where the power cord enters the enclosure. If your set does not have one of these, then the fuse may be located directly on the power supply circuit board itself.
Try testing that fuse for continuity with a voltmeter (with the set unplugged of course). If that fuse has failed, then it will test OPEN. If you are lucky, you may then just need to buy an exact replacement fuse and then install / solder that into place to correct the problem.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Jun 28, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
32ta1600 tv does not have any picture or Display, Cannot even see Menu on TV only sound. How to rectify?
This looks like a problem with the back-light inverter.
Since you can hear sound you can place a bright flashlight against the screen. Look for a moving image around the edge. This verifies the picture is being processed.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement) or have a friend with knowledge/skill you can fix it.
You will have to get a replacement board for your set.
Remove the old board from the back of set.
Install the new board.
That should solve the problem.
Mar 01, 2011 | Philips Televison & Video
We own a Kenmore 790.9611 electric range which is fairly new, only 2yrs old. Suddenly our baking element stopped working so we contact sear and was lead to believe the element had gone bad, we order a new...
Replacing the timer (called an Electronic Oven Control - EOC on most ranges) is a simple process that anyone can do. Just follow these steps:
1. UNPLUG the range. Dangerous voltage is still present even with the unit turned off.
2. Remove the back panel of the operator console.
3. Disconnect the electrical connections to the EOC.
NOTE: Write down or label where these wires go. Most EOC boards have the wire colors printed on the circuit board. In addition, there's usually a wiring diagram inside the operator console or on the back of the oven that lists the wire color codes as well.
HINT: If you have a digital camera, taking a picture will help as well.
4. Remove the mounting screws that hold the EOC in place and remove.
Most EOC boards do not come with the overlay. This is the pre-printed plastic cover that is affixed to the front of the board where the display and buttons are located. It is reusable and all you have to do is carefully remove it from the old board and install it to the new one. Just make sure you properly orient the EOC before placing the overlay on it, or you may be putting it on upside down.
If you have any further questions about this repair, please let me know. I hope this helps you.
NOTE: Nearly all manufacturers have the same policy about returning electronic parts that have already been installed in an appliance. There is a certain percentage of consumers that improperly install parts and damage them. Because of this, the manufacturer will not accept anything as a return that has been installed. This is not to say that you have done anything wrong. The heating elements on these ranges can often go bad and also cause the relay on the EOC that controls it go bad too.
Nov 06, 2009 | Washing Machines
We bought a new replacement lamp XL2200U for our Sony 60" KDFE60A20 TV, but we need to know how to install it...Please help We removed the old lamp, bulb and casing together, and I ordered the replacement...
Yes, lamp installation procedure is written in user manual of TV and click Sony Support to download user manual copy if required. Lamp replacement is simple process, take out old lamp and slid in new lamp.
Please buy Sony original lamp for TV safety.
Nov 05, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
My tuner has quit working. All other inputs work okay. TV is 4 years old. Is is worth repairing? If so, what is neede to fix it?
Your symptoms sound like the tuner has just stopped working. I have replaced tuners in sets for years and the repair is not the difficult if you have a low wattage soldering iron, I would recommend a 45 watt iron.
I know if may sound simple, but the tuner is a small silver box inside the set on the signal board that is replaced as an entire unit. I usually remove the signal board to remove the tuner and install the new one, just be careful with the circuit board while it is out.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to a person and get a status on price and availability.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 11, 2009 | JVC HD-56G886 56" Rear Projection HDTV
How to install a power jack for a acer aspire
You need to remove the main board to get at the bottom, the solder side. You'll also need an appropriate size soldering iron and solder wick for unsoldering the old jack. And of course you will need the replacement jack.
The hardest part is removing the board. You need to remove all the screws necessary to take off the keyboard, display and top cover. Then you need to remove any modules (hard drive, CD drive, etc.) as required. Finally you can take out the screws holding the main board in and lift it off the bottom cover. Replacing the power jack itself is a simple soldering job (if you have the tools and experience). Use solder wick (or a desoldering iron) to unsolder the old jack, put in the new one and resolder the connections.
The disassembly process for most models is basically the same. There are a number of videos on youtube showing how it's done for a few models. You can search youtube to see if one is the same model you have, or just watch a few of the videos to see the general procedure.
It's not an impossible repair if you are patient, have the necessary tools (small screwdrivers, soldeing equipment, etc.) and enough room to set parts aside as you work so you can keep them organized. When I worked at a computer shop our repair charge for jack replacement was around $100, so you can save some money if you do it yourself. But you can also do more harm than good if you're not careful, so you might want to get an estimate if you're no sure.
Good luck! If you have found my solution helpful, please take a moment to rate it accordingly. Thanks for asking here!
Mar 03, 2009 | Acer Computers & Internet
Replacing the digital board: bp94-02084a
Actually replacing most modules in the DLP line are fairly straight forward and you could probably do it with some care and patience. But there are MANY screws and wiring that need to be removed before you get to the board and that can be overwhelming in itself... You just might be far better off to leave the Tv fixin to a tech - who would look pretty stupid trying to put a digital sign together.. :)
Aug 21, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
