All wires that go into my Mp3 have to be bended at certain angles in order to work even though the wires aren't broken.
  • 8,596 Answers
Mp3 players are sensitive - try a different set of headphones first. Depending on the kind of mp3 player you have, this issue may not be fixable - you will just have to find the right spot and hold very still.
Posted on May 23, 2008
PTO quit engaging
check for a loose or broken wire to it .
Aug 19, 2016 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
1986 1340 harley turn signals out
Once you've tested all the fuses, check the bulbs. If the filaments aren't broken and the terminals aren't corroded, you may need to replace the wiring. If it's just corrosion, a bad fuse or burned-out bulbs, though, get a packet of the dielectric grease for headlights at the auto-parts shop and put a dab on each connector when you replace the bulbs. That should sort it out.
Sep 06, 2012 | Motorcycles
Garage door continues running even though sliding switch contacts end limit switch. Bends running bar. Only when closing- brown wire not broken
My guess is that the limit switch is not working or otherwise it would stop! Repair or replace the end limit switch. Do you have an OHM meter? if so OHM it out both open and closed if it does not change then it is bad.
Aug 22, 2011 | liftmaster Craftsman Garage Door Control...
Some pictures aren't appearing on the list on my MP3 Player at all even though they're all in JPEG format
You will have to set the correct resolution of the image before transferring to the player.Pictures having very large resolution cannot be opened due to pixel limitations on the screen.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thank for choosing Fixya.
TinuAlbinAlex
Jun 13, 2011 | Sony Walkman NWZ-S616F MP3 Player
Can I add a mp3 of my choice as a ringtone/ message alert
Not for now, Microsoft says they will implement this in a future update (maybe with the next update at the end of year 2011 which will bring also Internet Explorer 9 to Windows Phone 7 mobiles).
May 05, 2011 | HTC 7 Mozart Cell Phone
My laptop display becomes unusable when moving the display. There is only one angle that the display will work
This indicates that the wire bundle running through the hinge has been compromised. Some wire has frayed apart and is making intermittent contact with itself or the lid movement is causing the wire bundle to pull on one of the video connectors.
In order to fix this problem, you will need to remove the notebook's front hinge cover & check the bundle of wires connecting the motherboard to the LCD screen. If this bundle of wires is damaged, then you will have to get it replaced.
Dec 18, 2010 | HP G60-235DX Notebook
Headlights go out while driving
Hi, sounds very like you have a broken or sandwitched wire in your column wiring. Chances are if you have a look at the wiring from the column with a torch, you'll be able to see the problem area & rejoin any suspect wires which should fix the problem, hope this does the trick :)
Apr 20, 2010 | 1999 Dodge Dakota
Our 89 Jeep cherokee took a shot in the passenger front tire in an accident. Now at certain speeds the front end begins to shake drastically.
First thing to check is air pressure,
Second is to have that wheel put on a spin balance machine to see if the tire's steel bend shifted,or the wheel got bent,or a weight came off.
If all those check out,Then check the steering for any loose parts,
The last is check the front alignment.
Nov 17, 2009 | 1989 Jeep Cherokee
Reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
May 16, 2009 | Bosch RS15 1 1/4 Reciprocating Saw
Samsung YP-U3 mp3 - Can't get my songs to play in certain order
I've never seen a MP3 player that you can select the order in which multiple songs are played, unless you do it manually or only have the song you want to play on it.
I think your efforts will be in vane.  Sorry
Apr 12, 2009 | Samsung YP-U3JQB MP3 Player
 Grubhead
Grubhead
