NEC washing machine NW891 NOT WORKING after getting turned off half way during wash cycle
  • wesa Dec 02, 2008
    We have an NEC washing machine NW891 and it has come up with the error E9 half way through a wasing cycle. The machine is still full of water.
After ringing nec i have found that this is a water sensor error and that the sensor needs replacing also you may want to disconnect the drainage hose and let the water drain out
Posted on Feb 18, 2009
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Nec nw891 washing problem
Check your drive mechanism further, something caused it to come unscrewed. I would go deeper and see if I could find anything that could be out of balance or worn, that would have caused the screws to come out.
Mar 08, 2014 | Washing Machines
The washing machine is stopping half way through any normal cycle, seems unable to spin then stops. the spin is working on a rinse cycle
Possible that the suspect is the main program controller unit. You will need to check the voltage to the motor during the wash and spin cycle.
If there is no voltage then the controller can be faulty.
Feb 05, 2011 | Zanussi Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jul 19, 2009 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Wash cycle operates on low loads only
This sounds like a classic capacator fault.
Nov 06, 2008 | Whirlpool AWM5104/1 Front Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
305 people viewed this question
Top Washing Machines Experts
