Question about Philips 50PF7320A 50 in. Plasma HDTV
My 50 inch plasma
I got a philips 50 inch maybe 2- 3 years ago, i turned it on and a red light  turned on blinking i turned it off after that it didn't want to turn on no more
  • 4 more comments
  • dawnzy Aug 13, 2008
    I have the same problem, but mine never blinked. Just stopped. Dead. Nothing. Nada. Called Phillips and they said to take off the power cord and leave it "unplugged" for 60 seconds. Did that...nothing. So he said I have to call an authorized repair man. I even left it unplugged overnight hoping it would heal. Nothing. Now I found a guy that will service it in my home. Another wanted me to bring it to him. This thing weighs 800 pounds!! So the guy that's coming speculates that it's the power supply. Said these TV's only last about 2 years. Great. I have 2 of them. I'll keep you posted!!
  • Anonymous Sep 19, 2008
    I have red light blinking and power wont come on,I have tried unpluging it but doesnt reset itself
  • Anonymous Oct 18, 2008
    I am also having te same problem with the "RED LIGH". Please don't tell me I spent $2k on a TV that last only 2-3 years!! What needs to be done to correct the problem ?
  • DREWPY Nov 13, 2008
    DREW (
  • groovygirl Dec 30, 2008
    I have the same problem with mine. Red lights flashing and nothing happening. I have discovered that if I unplug it for a minute and retry, it will eventually come on. This usually takes 4 or 5 tries (about 10-15 minutes). About a minute later, the sound finally comes on, after a lot of crackles and hisses. However, I can go to my 10 year old, super cheap, non-flat, non-fancy tv, and it comes right on. Sound and picture in a split-second! Why are these things so expensive, if they aren't good quality and don't last? Oh well, live and learn. Next time, let the Joneses win!
  • Anonymous May 13, 2009
    This problem occurs because of a failure in the SSB (Small Signal Board). This is error code 063 by the way. These a faulty modules from the looks of all the failures I read on the internet. Repairman wanted $700 to repair this. I am buying a used SSB off Ebay and am going to attempt the repair myself. I invested $7.95 also for the technician's manual (available on the internet) to help with the procedure. I'll let you know how I do.
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
Posted on Feb 03, 2009
Great...I've got the same problem. Tv ewnt out on it's own lastnight and now it's just red light blinking. Please let us know how much it's going to run. Thanks in advance.
Posted on Oct 18, 2008
50 inch philips plasma has problems turning on. I replaced all the bad capacitors and now the green lights come on and then goes into blinking red four times. I checked all the capacitors and all of t
More specific, please ! Finally, did you replaced all bad capacitors or only replaced the power supply unit ? Because there are many other capacitors on other places that can be damaged.
Sure, the problem seems to be from one of the capacitors, but you have to know how to find the damaged one (and with the proper instrument will be more easy). Howewer, to buy a good instrument is more expensive than to service your TV set (my opinion). Plus guaranty.
Sep 11, 2017 | Televison & Video
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
My 50 in philips ambilight plasma will not turn on and blinks a red light 7 times and repeats
The failure with your plasma is with defective capacitors in the power supply.
Check the link below with info on how to DIY.
Jul 16, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
Dec 28, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips 50 inch plasma tv. The light is
Most Likely the power supply board has a few capacitors blown.You can repair it by removing back cover power supply board will be at the center of tv.Look for caps that have a round top these are the bad ones replace with same value caps.You will have to take power supply board out.Be careful these power supply boards have alot of voltage store in them.
Jul 24, 2009 | Philips 50PFP5332D 50 in. Plasma...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Plasma tv wont turn on
email me I may be of help to you.... Just fixed 2 of my 50 inch plasmas that wouldn't turn on after having a year. Does it pretend like its going to turn on then turn off then blink red LED?
Jan 16, 2009 | iLO 3200 32 in. LCD Television
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips 50PF7320A 50 in. Plasma HDTV Logo
592 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
