Question about HP LaserJet 4 plus Printer
Adding memory to laserjet 4
I have a new 4meg simm card for my laserjet 4. where do i put it? how do i physically install it?
    Problem Solver:
  • 7 Answers
Flip open the top cover, and look on the top of the right side cover, there is a latch,
push it down to release the side cover, and pop the back of the right side cover off, the side cover will flop down. You'll see a large metal access door with two screws, take out the screws and open the door, and you'll see the memory card slots.
Hogdoctor
Posted on Jun 02, 2008
Camera won't take pictures. Everything shows it is working put when you put Simm card to check pictures no pictures on it. Re formated the card put a
Check the memory card to make sure that it is good and capable of storing picture data. Easiest way is to try another card and see if camera does the same thing. If so then the issue is with the camera's electronics.
Oct 23, 2015 | Cameras
Beep error 1-3-2 how to resolve it, i have 5 RAM's every RAM have same output or error. please give me the solution
Take out all of the SIMMs. Put one in and power on the PC's
If this errors then take that one out and put another one in. If this errors do the same for the others.
You may also find that removing one of the SIMMs sticks will allow the system to start. As they may have to be added in pairs. ie. You have 2, 4 or 6 installed. But 5 will not work. Check the Dell site to confirm "configuration of Memory".
Jan 11, 2014 | Dell Dimension 8200 PC Desktop
Adding memory to PCV-RS322X I have two 1 Gig cards to add and there are 4 memory slots, which slots should they be installed in, fill up one bank or put one card in each bank?
SONY VAIO CAN ONLY TAKE 2 GIGABYTE.YOU HAVE 2 GIG SO I SUGGEST YOU REMOVE YOUR OLD MEMORY AND INSTALL THE NEW 2 GIG IN THE SAME PLACE THAT OLD MEMORY
Jul 03, 2013 | Sony Vaio PCV-RS322X PC Desktop
Hp laserjet 1536dnf error 79
Error 79
Software/drivers, Memory PCA's, Font-Macro-Personality Cartridges, option I/O Cards. Defective toner cartridge in the Laserjet 4 Plus only. Remove any accessories (font cartridges, memory PCA's, SIMMs, etc.) plugged into the formatter card and try again. If the problem persists and is application specific, verify proper setup with application vendor.
Defective Formatter PCA - Replace with known operational board and try again.
Firmware Update - The configuration page lists the firmware version of the product. Depending on the model, a firmware
DIMM may need replacing or a flash update. On flash-memory-based products, you can update the firmware code by downloading the latest flash executable file for the product and running the program according to the readme instructions posted with the update file. If the firmware should become corrupted or fail (usually because of an interruption when attempting to update the firmware), the product will no longer function. In this case, a firmware recovery DIMM is available.
Reseat DIMM, then Formatter - Replace or flash DIMM then formatter
Can this also be?
Jan 03, 2012 | HP Laserjet M2727nf Multifunction Printer
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
How do you open the case to install RAM?
Instructional steps
  • RAM
  1. Determine what kind of RAM you need, and whether your computer has enough open slots to hold it. The new RAM should match the existing RAM's specifications and configuration.
  2. Shut down the computer and leave it plugged into the surge suppressor.
  3. install-ram-1.3-120x120.jpg Disconnect all peripheral devices, such as the monitor, from the computer.
  4. install-ram-1.4-120x120.jpg Remove the computer cover.
  5. Ground yourself to the computer with professional grounding equipment like an anti-static wristband or hold a metal part of the chassis.
  6. Remove any cards or internal components necessary to give yourself unobstructed access to RAM sockets.
  7. install-ram-1.7-120x120.jpg Pick up your SIMM (single in-line memory module) or DIMM (dual in-line memory module) by the ends without touching pins or chips.
  8. install-ram-1.8-120x120.jpg If adding a SIMM, find the notched end and turn the SIMM so that it is parallel to the existing RAM card(s). Insert the SIMM into the socket at a 30-degree angle. If adding a DIMM, insert the DIMM straight in so that it is perpendicular to the motherboard.
  9. Use slight pressure to keep a SIMM from backing out while rotating the module to an upright position perpendicular to the motherboard.
  10. Make sure the small holes on each side of a SIMM fit into holders
  11. install-ram-1.11-120x120.jpg Feel or hear retaining clips lock a SIMM into the socket; close the side clips on a DIMM.
  12. 1 Gently try to pull the module out to ensure it is locked in position.
  13. Replace all internal components.
  14. Leave the cover off and reconnect the monitor, keyboard and mouse.
  15. Turn on the computer.
  16. Check the amount of RAM by right-clicking the My Computer icon in Windows and choosing Properties. On a Mac, use the About this Macintosh command in the Apple menu.
  17. If you don't see the right amount of RAM, turn off the computer and try "reseating" the SIMM or DIMM (take it out and put is back in) and reboot. If that doesn't work, call a technician.
  18. Shut down the computer and disconnect the peripherals again.
  19. install-ram-1.19-120x120.jpg Replace the cover and reconnect all the peripherals.
Oct 06, 2010 | Apple 24" iMac Desktop
I have a dell dimension 4600 and would like to install 2 one GB memory sticks. I would like instructions on how to install them
Go to this site for information about the 4600.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm#1111336
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
Initialization flash simm memory on LJ4+
You don't have to initialize the extra memory on that printer. Just install it and when you power on the printer it will recognize the extra memory. If you mean install, then go to www.HP.com and look at the instruction manual in the support section. I believe you have to extract the formatter board from the rear and then you should see the place where the chips should go.
Apr 09, 2009 | HP LaserJet 4 plus Printer
Adding memory to tx pro mainboard
You do not say what memory you are trying to install.
The ASUS P4S800D motherboard has four memory slots that hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot, so the installed maximum is 4GB.
DDR memory is generally available in 128MB, 256MB, 512MB and 1GB modules. If you already have memory installed, it must be at least 128MB so you cannot add modules to 'bring memory to 128'.
Either you have a different motherboard and posted in the wrong section, your memory calculations are wrong, or you have used older PC-133,PC-100 or PC-66 memory instead of DDR. The last is unlikely as older SDRAM has two notches and won't physically fit into a DDR slot that only has one notch.
Please re-post with the specific motherboard model just to confirm and a list of the memory modules you are trying to use.
Jan 01, 2009 | ASUS P4S800D-X Motherboard
HP LaserJet 4 plus Printer Logo
70 people viewed this question
Ben Johnson
