Here are the pinouts for the 4 wire and 6 wire D104 mics. they were great microphones back in the 1980s. I used to have one on my Ten-Tac HF ham radio.
Astatic (4 wire) Astatic (6 wire) 1- Shield 1- Shield & Blue 2- White 2- White
3- Red 3- Red
4- Black 4- Black Yellow NC
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Astatic - 4 wire
1- Shield
2- White
3- Red
4- Black
static - 6 wire
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S - 4 wire
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner RK56 Road King
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Regards,
Tony
here is the info you asked for the following is the correct wiring.
Mic Wiring Info Stock Mic Wiring 1. Ground Shield 2. Audio Yellow 3. Transmit Red 4. Receive Black 5. CH. Up White 6. CH. Down Blue Turner 4-Wire MIC. Wiring 1. Ground Shield 2. Audio White 3. Transmit Black 4. Receive N/C 5. CH. UP N/C 6. CH. Down N/C
Turner 6-Wire MIC. Wiring 1. Ground Shield & Red 2. Audio White 3. Transmit Blue 4. Receive N/C 5. CH. UP N/C 6. CH. Down N/C
Astatic 4-Wire MIC. Wiring 1. Ground Shield 2. Audio White 3. Transmit Red 4. Receive N/C 5. CH. UP N/C 6. CH. Down N/C
Astatic 6-Wire MIC. Wiring 1. Ground Shield & Blue 2. Audio White 3. Transmit Red 4. Receive N/C 5. CH. UP N/C 6. CH. Down N/C
Offhand, the 4 pin mic connector and corresponding pin # would depend on the communications equipment the Astatic was initially wired for. However, the color coding of the wires in an Astatic would be:
white - mic audio;
shield/blue - gnd;
black - NC or speaker;
red - NO or PTT;
yellow - not normally used.
Good luck and Thank you for using FixYa. Happy Holidays.
1 shield blue 2 white 3 red 4 black 5150 buckeye
