Question about Toshiba Televison & Video
My cinema series television picture flickers and shimmers. It used to improve with time, now, not so much
    Scholar:
  • 106 Answers
It might be that it is a dlp, which uses a spinning colour wheel and a mirrored chip (looks like a very tiny mirrored checkerboard up close) to produce coloured images. your wheel might be slow because of dust in the bearings or the dlp chip might be old or getting worn out.
contact a service representative? see if it is under warranty? get a new one? that's all i can suggest at the moment.
Posted on May 23, 2008
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
I have a 55 in Toshiba Cinema Series HD the colors are out of alignment so I have three pictures stacked behind each other. Is there an adjustment or repiar
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Nov 09, 2010 | Toshiba TN61X81 61" Rear Projection...
Red shimmer in black areas
The fault could either be on the main PCB (logic - input/output) or the Y-Sus PCB? Check the supply voltages for accuracy.
Aug 31, 2009 | Akai PDP4273M Television
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
After my ciurcut breaker was fliped on and off my samsung 46" 71f has had problems
Ive had a element lcd tv that i bought, out of nowhere the power cut off, so i went to flip the breakers, and since i had the Tv still plugged up, after i flipped the breaker to get the power back on. Power came back on, went to go turn on the tv, the light would be on but nothing on the screen no picture. Sometimes it would come on a little bit after awhile but that is it. So yes i do recommend you have there tech come out and fix it. Before you ever flip a breaker off and on, unplug all computers, tv's, anything in that nature before you do it.
Oct 31, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I need to remove and replace my Lamp Unit for my Hitachi 50VS810 TV
my Tobhiba cinema series model no Tn43v71 and series no 636649224 will talk but my picture is black if the power supply has malfunctioned can I reset it by unpluge the tv
Jul 31, 2008 | Hitachi Televison & Video
RE: Toshiba 27" Cinema Series
your problem is in the high voltage circuit.change your flyback it has a short.also check around for open diode in the same circuit.good luck
Aug 04, 2007 | Toshiba 27A34 27" TV
Picture - Flickers/Shimmers
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Oct 23, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
