Question about Dell Inspiron 1501 Notebook
USB Drives My USB drivers aren't working. All four of them slightly work. But they aren't working at 100%. I talk to Dell they tell me to flash my bios. That didn't work. Remove my Vista and put XP back on. That didn't work. Put Vista back on, that didn't work.
  • Dreman1731 May 23, 2008
    Ok, thanks.
  • sfard May 16, 2009
    Hi
    i have same problem
    but the diffrence is my usb work.
    if you want to copy a thing from flash memory to your computer they work but when you want to copy data from your laptop to flash memory it does not work properly .i change my opraeting system for sevral time but it does not fix.
    Scholar:
  • 106 Answers
Re flash your bios. again. or reset it to defaults if you know how to do that.
Posted on May 23, 2008
  • crabbypup May 23, 2008
    another thing you could do is try using a linux boot cd and seeing if they work then. you can get a small but functional one from here
    it should be less than 100mb and just burn it onto a cd, then put it in your laptop and reboot.(if it doesn't load, go into the bios and set the cd drive as the first boot option with the hard drive as the second)
My dell win7 desktop won't recognize my usb flash drives
Go to device manager and remove all the entries labeled USB ROOT HUB. After you have done that plug in a flash drive and allow windows 7 to install the drivers again. If this does not work you will have to go
May 19, 2014 | HP PC Desktop
Windows 7 Cannot find drivers for Maxell 4 GB USB 360
Good day
USB Flash drives use a standard windows driver. This means that the first thing to test is to see if any other USB drives works on your dell laptop. The second thing to test is to use a different USB port. This should eliminate hardware failure. I would recommend simply toing into device manager and look for the universal serial bus controllers. Listed will be all the USB drives. You can simply uninstall all the drives and restart the computer. This will force windows to reinstall the drivers.
Jan 30, 2014 | Maxell 4 GB USB 360 USB 304 - 503201 Hard...
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
I have a 4G mini usb drive but the computer doesn't detect it. I tested it in a Dell printer to scan to usb and works ok. I'm running windows XP in my pc. Do you have a driver to install it or any...
Click Start
Right-mouse click My Computer
Click Properties
Click Hardware
Click Device Manager
Look to see that the USB ports are correctly detected, and that their device-drivers are loaded.
Try a different USB device in your computer; if it also does not work, then you have a problem with your computer, _NOT_ with the PNY flash-drive.
May 12, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Dell dimension 2400 usb not working
Hello.
Your Dell has two front-panel and four back-panel USB 2.0 ports.
If NONE of the USB ports are working (and I'm figuring that you have tried other USB devices to eliminate a faulty USB device), this is usually caused by a drive letter conflict. The best way to resolve it is to remove all USB devices, then uninstall the USB controllers and hubs from Device Manager, then reboot and allow your controllers/hubs to reinstall.
If still a problem, use disk management to assign higher drive letters to the existing devices. For example, a permanently connected external hard drive and card reader can be set to V and W. Generally, newly connected flash drives will take the next available letter.
Hope this helps.
Jun 30, 2010 | Computers & Internet
Flash drives inserted in usb ports shuts down
make sure there is no virus in flash drive boot the system in safe mode and run complete scan the system and flash drive.
Jan 14, 2010 | Office Equipment & Supplies
Sandisk cruzer profile usb flash driver with finger print scanner
I don't even wanna talk about how incredibly complicated this matter can get.
best I can tell you is pray and don't give up , and if all else fails
sue the **** out of sandisk and microsoft
Aug 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Flash drive
Hi phun2008
Did your question get answered? (I'm not sure what "no thanks" was in response to.)
Your flash drives should work fine w/ Windows XP. They should be detected by the operating system as mass storage devices - plug-n-play - w/ no need for drivers installtion, etc.
You may, however, experience detection issues w/ them on systems w/ older USB hardware. If the flash drives are USB 2.0 drives, they will not be detected on systems running USB 1.1 or earlier - regardless of the OS (operating system) installed.
On the other hand, if they are USB 1.1 flash drives, they should be detected fine on both older and newer USB ports as USB 2.0 is "backward compatible".
I hope this helps.
BJ
Apr 03, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
278 people viewed this question
Alun Cox
