Question about Kenmore 15864/15862 Top Load Washer
Waher wont stop filling
I have a kenmore series 90 washer i just replace the coupling today but now it wont stop filling and it keeps overflowing what should i do
  • Baseball22 Jan 27, 2009
    I have a similar problem and have already replaced the water level switch to no avail. Mine overflows intermittently and tried blowing thorugh the hose which is clear. Any ideas ?
  • Anonymous May 02, 2009
    It wont stop filling
  • 550 Answers
If you had the unit apart, It is possible as well as Lumpy816 correct answers, for a surge in the pressure sensing line to stretch the tiny spring inside the level sensing body.
if replacing the hose does not rectify the problem
Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed
  6. test, adjust, test adjust.
  7. if no effect replace water level sensor body
Posted on Jun 17, 2008
  • 246 Answers
Check your pressure hose. To check the first end, pull your washer forward and tilt it back about 45 degrees. On the right hand side towards the back you'll see a clear hose coming down and "pugging" into the tub. Make sure it's in place. To check the other end, open the console and make sure the other end is plugged in to your water level switch ( far left hand side of the console. If you took the cabinet off to replace your coupler, make sure you didn't pinch the hose against the back panel when you put the cabinet back on.
Posted on Jun 16, 2008
How to fix a Kenmore 90 Series when the water keeps running?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this will help you to fix your washer,
Aug 09, 2011 | Kenmore 22422 Top Load Washer
How do you remove the back of the Kenmore 90 Series Washing Machine? I am troubleshooting the problem that my machine doesn't stop filling and overflows.
Most Kenmore washers are made by Whirlpool. If yours is this page will help
Note that I cannot know without the full model number but follow that page and if it doesn't seem right your washer may not be Whirlpool made.
Sep 24, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore Series 90 Washing Machine water will not stop filling during rinse/spin cycle. Why?
This problem is commonly attributed to either a water inlet valve that doesn't shut off, or a pressure switch malfunction. The following links explain how to diagnose the problem and repair as necessary:
If the washer is not overflowing, the likely problem is the water inlet valve. If the washer fills to the point where it overflows, the easiest and most common cause of this problem is the small plastic air hose on the pressure switch coming loose. It can usually be fixed by simply reattaching the hose. However, read through all the information provided and double check everything to make sure.
Replacement parts (if required) can be purchased at any of the following websites:
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
May 02, 2010 | Washing Machines
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Washer
Apr 18, 2009 | Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
212 people viewed this question
Sal De
 Brian Main
Brian Main
