Question about Pioneer PRO-510HD 53" Rear Projection Television
Cleaning mirror how do i take off the front of the unit so i can clean the mirror? THANKS
    Genius:
  • 1,139 Answers
Hello mrdish,
the mirror is in the attached to the top rear panel, remove the top rear panel to clean the mirror.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 29, 2008
3 Suggested Answers
ramon49
  • 111 Answers
SOURCE: Cleaning the mirror?
usually near the controls there are some screws, remove, then lift aggressively without breaking. Use a eye glass cleaner from Wall mart or such. Need near lab grade alcohol. Can use DEP (home depot) glass cleaner. Be gentle use baby diaper and swab in one direction.
Posted on Mar 11, 2009
SOURCE: cleaning lens and mirrors
You have to remove the back cover by removing the screws.
Use a microfiber clothe and be gentle.
Posted on Jan 20, 2008
After scanning a document, a line is on document
Hello Norma,
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 16, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Black line 6130
Thanks & regards,
ScanCare
Apr 25, 2013 | Fujitsu fi-6130 duplex scanner
Picture problems
Two things to look at from rear with back off: one is the inside of the screen and or the large mirror in rear of unit--do not touch mirror.
second is the unit has a small lens (2-3 inches) the points up towards the mirror---dust or such on it will cause this--it can be cleaned with a lens cloth.
If the mirror has this (uncommon) the entire front of set would have to be removed (screen units) and that is not real easy.
If lens and mirror and screen are ok problem is INSIDE the optical unit that the lens is part of---on rare occasions that can be cleaned out with compressed air.
without seeing a photo of what it looks like this is all I can suggest.
Oct 22, 2012 | NEC Toshiba 42Hm66 42-Inch 720P Dlp Hdtv:...
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
How do i remove the screen to my Mitsubishi wd-62638
For the model indicated (WD-62638) the entire screen unit needs to be removed.
Some models had two mirrors--the usual large one in back and a tiny one in the bottom front.
1. Locate and remove front plate below screen (where you may access the lamp as most of these are taken out from front)
2. Remove all the screws ON THE BACK OF THE SET around the top and both sides.
3. Remove a plate behind the removed lower front grill and there you should find a set of wires that go to front keyboard.
4. With that done look carefully at either front side below the screen unit---one screw on either side---do not remove but just back them out.
5. 2 person job---the entire screen unit lifts up and out.
6. DO NOT try to clean the large mirror---if touched with hand or your hair it will smudge and it will show in the picture.
7. If the little mirror is there at the bottom---it can be cleaned with glass cleaner---
8. Insert the screen unit back with the two front lower screws supporting it (have someone hold it in place until you line up and install all all the rear and then the 2 front screws.
Let me know if you have questions.
Mar 10, 2012 | Mitsubishi WD62628 62" Projection HDTV
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
I have opened the above door and have cleaned the mirrors front
check the cables connected to scanner pcb monted left side of the machine. there is a flat cable connected to the pcb from scanner unit. layer of contacts may not be correct. check, clean and re-inatall the cable.
Dec 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Non working unit
just clean all mirrors & lense of front side CCD
Oct 23, 2008 | Fujitsu FI-4860C2
Ricoh ft 3213 printing problem
Is it only when you use the top feeder? Check by placing an original on the glass and copying if the same fault then there are three possibilities
  1. Optics Dirty (Dust on the copying mirrors) Remove glass and clean the mirrors on the scan unit also remove the lens cover and clean the mirrors under there replace lens cover clean glass and refit. (Do Not remove any mirrors you can clean them in there place and use a glass cleaning solution)
  2. Toner Waste and drum cleaning unit full. Open front cover and split machine as to remove jam not touching the drum (Large Cylinder ) check there is no banding on there. IF so to the left of drum there is a unit that contains the cleaning blade and fills with waste toner remove vacuum out waste toner check that cleaning blade ok and reinstall. Close and check machine if ok then great if not could be fault number 3 or that the cleaning blade is worn and need replacing.
  3. The fuser section (Heat section) While the machine is split look at the bottom left you will see a Orange unit this is the fuser section that houses the heat roller which welds the toner to the page. Check that the top roller is OK that there is no toner stuck on it and the Teflon coating is even. If not then the fuser will need replacing and as you said that you are missing text the most likely faults are going to be the fuser or the drum or the drum cleaning blade.
I hope this helps you
Thanks J
Jan 18, 2008 | Office Equipment & Supplies
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
Pioneer PRO-510HD 53" Rear Projection Television Logo
344 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
