Question about Whirlpool AWM8143 Front Load Washer
F9/FA Whirlpool 6th sense frontloader washer
When starting F9/FA - water starts - 10 secs then stops and f9/fa appear please help thanks Lyn
  • Anonymous Mar 16, 2014
    whirlpool cabrio automatic washer with 6th sense making a noise that sounds like change is in the machine or outlet for the water to drain - can money get inside?
  • Anonymous Mar 23, 2014
    F9 and E1 flashes and the washer cycle stops, lots of water stays in the drum.
    Problem Solver:
  • 6 Answers
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
I had this happen to my machine on Friday. My husband fixed it last night and it cost $6.59!!!!
One of the hoses inside (i think it was one from drum to drain hose) the machine was rubbing against something which then created a tear in the hose. The hose was leaking and therefore activated the float switch and FA F9 response. The hose is a small black rubber one about 15mm in diameter. My search for a replacement hose took me to Repco where i got fuel injection hose ( which wont be getting any holes in it i assure you!!!!). I could have ordered a part but it was going to take a week and I can just imagine they would have charged thru the nose.
Posted on Jul 17, 2008
  • Dudus
    Dudus Dec 17, 2013
    Hi, thanks for the post, it really saved my day. My 10 years old AWM8125 sixth sense stopped working after starting filling with water, showing F09 and FA shortly after. I followed the advice in this and another post so I checked the above mentioned hose, first, after taking out the upper cover, by blowing air in it with a 150 ml syringe - no pressure at all was building in it. Secondly, I removed the rear cover and I checked the hose. It was loose at the drum-end. I fitted it back and I tested the washing machine with a rinse programme with the drum empty, before reassemblying the covers. I worked just perfect. I reassembled it and now it's washing fine.
    New Friend:
Posted on Dec 17, 2013
  • Dudus
    Dudus Jun 06, 2014
    It's still working perfect after 6+ months
New codes for telewest starview please posted ones not working
09/10/09
Telewest 00 = CF 53 0C 33 79 61 71 85
01 = D2 F9 3F 22 0C A7 D6 C9
Oct 08, 2009 | Computers & Internet
Eurovox codes for 8th october
Oct 08, 2009- todays codes
CW Keys 5C01 updated 08/10/09 10:35
00= C5 BE AF 36 0A 61 91 AA
01= D2 D1 80 FA 21 85 0F 53
TW Keys 5A01 updated 08/10/09 10:35
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 35 22 0C A7 D6 C9
NTL Keys 5401 updated 08/10/09 10:35
00= F0 0E 91 E0 2D C1 C5 FD
01= 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need 5c01 ex cw starview
C & W 5C 01] 08/10/09
00 = C5 BE AF 36 0A 61 91 AA
01 = D2 D1 80 FA 21 85 0F 53
Telewest 5A01 08/10/09
00 = 83 5D12 B8 96 F6 1F C4
NTL 54 01] 08/10/09
00 = F0 0E 91 E0 2D C1 C5 FD
01 = 5D 61 B2 C8 E7 DD F9 57
Has anyone got the codes for starview box please im stuck!!
Oct 08, 2009 | Intel CPU
Telewest Codes 08/10/09
NTL 54 01] 08/10/09
Need new codes for starview box fife as the previous ones dont work
NTL 54 01] 08/10/09
Does anybody have the new codes for telepest they have gone off again today pls. 8 oct 2009
Codes again
Awm8143 FA code
Service manual say FA is "aquastop failure- check aquastop switch", (aquastop switch is flood switch located in base of machine), however looking at the parts view of this machine, it doesn't seem to have a flood switch-odd.
F9 is an overflow problem- manual says to check pressure switch.
Both faults seem to indicate either a leak or overflow problem- remove rear panel and check base for any water, which would indicate a leak.
If OK, next step would be to remove front panel (remove wire and spring from around door seal, remove 2 screws holding door lock, remove 3 screws along base- front panel comes off by pulling down and out towards you-can be a bit tight)
Pressure switch is located just above door lock-it has the black tube going to it- remove tube and blow into switch-you should hear it click.
Also check the chamber that the other end of the tube connects to on the bottom front of tub- this chamber can get blocked up and cause overfill problems.
Please note- always disconnect from power supply before attempting any repairs. If in any doubt, best to leave for an expert.
Good luck!!
Aug 11, 2009 | Whirlpool AWM8143 Front Load Washer
Code F9 and FA later
Thanks for help,it is fixed
Apr 05, 2008 | Whirlpool Washing Machines
Whirlpool AWM8143 Front Load Washer Logo
3,264 people viewed this question
Dan Webster
Dan Webster
Sal De
