Tripp-lite KVM B030-002-R
Hi, I saw your response to a forum question, I was wondering if you could help with this issue,
When I do the scrl-scrl up etc...It says: Analog input, cannot display this video mode. Does that make any sense to you?
thanks,...
aryanavisha
  • 3 Answers
SOURCE: 8 port kvm console switch
KVM switches are hardware based and there is no use software.
Posted on Jan 28, 2008
SOURCE: Tripp Lite B034-002-R 2-port
press numlock twice. There may be other hotkeys, but that's the one that I use. Occasionally mine gets confused (because of reboots and hibernation) and I need to unplug the usb cables from each PC and then plug them back in. Then it works again.
Posted on Jun 26, 2008
  • 1684 Answers
SOURCE: Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at:
www.ccl-la.com/badcaps.htm for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Sep 22, 2009
SOURCE: I own a Tripp Lite
I know it has been a long time, but I just experienced this same problem did you ever find a solution???
Posted on Nov 16, 2009
Zphinx
  • 60 Answers
SOURCE: Avocent KVM switch keeps turning
the switch should beep if you switch between channels or Ports.
It seems that you might want to download the manual and try to reset the unit. If this doesn't work call their support. Avocent has free support as far as I know.
Posted on Jun 16, 2011
WHAT ARE THE THE HOT KEYS
Hot Keys are either a single "Key" such as say the Ctrl button, or even a letter or number Key, on the keyboard or a group of "Keys" say Ctrl-Alt-Del, Shift- Alt-1, whatever. Usually the keys have a funtion assigned to them, and when the Keys is/are pressed on the keyboard, a certain action happens.. usually these are pre-programed OR user programed. Hope that helps.
Jan 21, 2010 | Tripp Lite B034-002-R 2-port KVM Switch
How do you switch between ports on a tripp-lite two port ps2 swi
usually you tap the <SCROLL LOCK> key twice then either hit the <backspace> key or the left or right arrow keys.
Oct 10, 2009 | Tripp Lite (B034-002-R) (B034002R) 2-port...
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 22, 2009 | Tripp Lite Lite 16-Port 1U Rackmount...
Jun 25, 2008 | Tripp Lite B034-002-R 2-port KVM Switch
Mouse not working KVM Switch
First question, jatraczyk - have you tried a different mouse?
Mar 04, 2008 | Computers & Internet
KVM Switch constantly switches from one computer to the other
You have to hit num lock 2 times to get it out of autoscan operation. You have to hit the num lock 4 times to put it in autoscan operation. Hit Num Lock 2 times to switch between your PC's Here's the manual in case your missing yours: http://www.tripplite.com/support/manuals/manuals_bymodel.cfm?modelID=2911
Apr 03, 2007 | Tripp Lite B034-002-R 2-port KVM Switch
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
