Question about LG 42PX5D 42 in. Plasma HDTV
LG remote control
My LG remote control to my 42 inch plasma tv just stopped working. The function buttons illuminate, but the tv will not react to any button. I changed the batteries, and it worked for about five minutes and now it is doing the same thing. I changed the batteries again, and it still won't work. Help.
  • rx2cre8 Jun 02, 2008
    remte control not activating TV, TV has worked for almost 12 months to the day but now nothing..........any solutions 42LC2D series
I have a lg tv that did the same,lg came out and changed the mother board.worked for 3weeks and has started again.im lucky ive been offered a full refund. as i only had it 8weeks. this is a known fault to lg. if i were you i would call lg and kick up a fuss.try and get your money back or a free motherboard. as for me i wouldnt touch an lg item again. hope this has been some help
Posted on Jun 01, 2008
My remote for my 42 inch lg plasma tv won't work the tv. I replaced the battles and that didn't work. It lights up green when I hit the power button
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 04, 2015 | LG Televison & Video
The picture on my lg tv has gone dark. Every button on the remote is working except the menu button.The button on the side for menu is not working either.
Check and repair the remote control. It sounds that it need cleaning. But lack of brightness to a Plasma screen might be to a faulty Z Sustain board. Check this for more details about the TV fualts, and to how to repair and clean a remote control.
Jan 05, 2013 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX4MVH remote control does not operate the TV, it seems that it needs to be re-synchronised, how do I do it? The batteries was replaced yesterday and the lights on the remote control flashes and...
Hello
If you are using its original remote control handset with this set, replacing batteries will poise no problem at all. If remote control does not works properly check the following.
Check to see if there is any object between the TV and the remote control
causing obstruction.
Are batteries installed with correct polarity (+ to +, - to -)?
Correct remote operating mode set: TV, VCR etc.?
The light at its side
Illuminates the remote control
buttons of selected mode.
OK.
Apr 26, 2011 | LG 42PX5D 42 in. Plasma HDTV
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 50 inch lg plasma tv and the picture is to big.
Ok take your Vizio remote control go to the Lower section of the buttons and look for the - Zoom + button than decrease the zoom.
Jun 19, 2009 | Vizio GV42L 42 in. LCD Television
Maxent 42 inch TV Keys locked and Remote will not work
See if you can reset the electronics to factory defaults. Also check with the mfg about this. If nothing works you have one sick puppy on your hands.
Try this - turn set on then pull the power plug. Then push and hold the power button to on position for a few minutes.
Release button and plug back in Turn on and see what happens.
Sep 21, 2017 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a 42 inch LG plasma tv which i bought 6 months agao, the remote for it stopped working, i replaced to batteries twice and it still does not work, the remote # is mkj42519603
Hi rampersad82, We need to check the functionality of the remote. Press and hold the up volume button, watch the light (led) on the remote. If the remote is workingyou will see a slight pulsing of the light. If it is not working the light will stay bright with no pulse. Let me know what you find I can assist further. lone99star
Jan 10, 2009 | Televison & Video
No digital picture
Try and reprogram all channels in the tv. Goto menu and use the auto program function to do this and see what happens. If this does not fix it then you will need to send to a repiar shop. The main pcb is most likly bad.
Nov 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
278 people viewed this question
Computer Repairing
Computer Repairing
