Question about Samsung Televison & Video
42" rear projection
TV will not come on. When it powers up. it's like a bell is ringing for 3 or 4 seconds and then stops. It will ring about every 30 seconds as long as the power is on. Any ideas?
  • 1 more comment
  • victory6 May 23, 2008
    TV is model # hlr4667wax/xaa
    Thanks for the tips. I will give it a try tomorrow after work. The manual is also pointing to this.
    Bulb was bad. Put in a new one today and it works fine. Thanks for the help.
  • Samsung Master
  • 8,617 Answers
I will need the model number of your set in order to even begin to help you out with your problem
Posted on May 22, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry May 23, 2008
    Try removing the lamp and reinserting it , see if that helps the problem. i have seen where the lamp isnt seated it can often sound like a soft ringing sound.
  • Sonny Berry
    I have seen that happen quite often.
  • Sonny Berry
    Youre welcome glad the set is working for you now
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung rear projection tv does not come on
The power supply circuit board has probably gone bad. Repair cost for an in home service call by the major players would be about 450$ plus tax usually with a 90 day guarantee.
Mar 14, 2010 | Samsung HCN4226W 42" Rear Projection...
I am trying to program our Simplex 6100 school bell timer. I cannot get the bell to stop ringing after a 3 to 5 seconds. I know it is something simple that I am not doing, but I have tried everything that...
am trying to program our Simplex 6100 school bell timer. I cannot get the bell to stop ringing after a 3 to 5 seconds. I know it is something simple that I am not doing.
Sep 29, 2009 | Hardware & Accessories
Tv appears to be getting power
Most of the Time STKs need to be replaced 2 of them STK392-110s ,they are big black ICs order parts on line or call 1-800-223-3205 or 1-800-628-1118. Also Ck all low ohm resistor around ICs 2.7 ohms usually there is 2 of them bad.
Dec 15, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence
In rear projection, there are 3 small crt's in the rear projecting off of a glass for viewing. All have a set of convergence rings on them, fined tuned so be careful not to rough handle them. You'll have to find the one that is bad, possibly by lightly trying to move the rings.This is a very long and drawn out process but to make it short. These are polarized rings, each ring will move a diff. color on your screen. There is a tighten ring on all three, it should br in the front of them all. Be careful. Have problems call 812-207-4521
Sep 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Tv issue
I have the same problem was there a solution to the problem
Jul 28, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung 42' Rear projection - High freq squeal
solder around pins on flyback transformer,see if this will solve your problem.some flybacks will make this sound, like a ringing noise.
Jan 19, 2008 | Samsung HC-P4241W 42" Rear Projection...
Televison & Video Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
