Question about Garmin StreetPilot C330 GPS Receiver
White lines across screen
The unit powers on fine, but shows white lines like bars horizontally, which makes it extremely difficult to use. I tried resetting, but to no effect. What gives?
  • Dave Crowell
    Dave Crowell Oct 23, 2008
    same thing.. white horizontal bars across the screen.. after like a month of use
    Problem Solver:
  • 4 Answers
Normally RCA"S are common with this problem. Some of them have a knob in the back the adjust the brightness. This will sometime get rid of the lines. I did it to my RCA and it worked like a charm.
Posted on May 22, 2008
Horizontal bars across top 1/3 of screen
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 21, 2016 | Sony 55" LED Internet TV - KDL-55EX640
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
Last night I turned my Polaroid TLX 04244B off, and had zero problems. This afternoon, I have a 6" pattern of horizontal lines across the right hemisphere of the screen. They come and go, darker...
You are probably seeing hum bars which may be due to an AC ground loop that is going through the shields of one or more of the cables inteconnecting the TV with one or more of the other video components. You should do the following to try to resolve it...
1. reseat all the interconnecting cables between TV and other units
2. have all AC power supplied by one power bar with a ground plug
Mar 17, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
Horizontal lines on screen.
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Audiovox D2010 Portable DVD Player with...
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Garmin StreetPilot C330 GPS Receiver Logo
778 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
