Question about HP Digital Projector xb31 Multimedia Projector
XB31 projector overheat
Hi, well the projector will work for +/- 1h30 then overheats and shuts down. The light indicates overheat, not temperature problem.. in the specs.. anyways, i put a new lamp in and it still does the same thing. It worked for 4-5 hours without shutting down when i tried it with the top cover open at 1 inch.
Thanks for your interest. Marc.
  • Anonymous Mar 08, 2009
    where do you get the sensor?
  • Anonymous Mar 15, 2014
    starts but shuts down
  • 563 Answers
Hi sun_md
This sounds like a typical temp. sensor that is faulty.
If you take off the top cover of the Projector and follow the cables from your fans to the Mainboard - you'll find a smallish board that regulates the heat of the Projector. You will also find another sensor on top of the lamp housing.
Try replacing the sensor that goes with the fans first , this is normally the one giving problems.
Good luck and thanks for using Fixya !
Posted on May 23, 2008
My Epson TW 700 suddenly went black,and the fan startet to go very fast.I could also see the red light ( temp. Indicator? ) coming on.Tried to cut the power, cleaned the filter and start it again, but...
Don't cut power to a projector when you power down. The fan has to run after the projector is powered down so that the lamp can cool evenly. If you unplug or if there is a power failure the lamp will develop cracks around the edges of the reflector and will fail quickly. If the fan is not moving air through the projector, it will overheat and shut down.
Nov 03, 2013 | Epson EMP-TW700 LCD Projector
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Jan 02, 2013 | Epson ELPLP41 EB S6 Lamp
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
Both red warning lights on the projector are blinking.
how about the fan does it works, then clean the filter.
Jul 18, 2012 | Office Equipment & Supplies
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
Dell 4100mp shuts down
It sounds like the fan in you 4100 is defective.
Jul 14, 2009 | Dell 4100MP Multimedia Projector
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
HP XB31 Projector heat senor
Hi Marc
How do you know that the sensor needs replacement ?
Could you please give me some of the sympoms first ?
This could be something other than a sensor.
May 04, 2008 | HP Digital Projector xb31 Multimedia...
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
HP Digital Projector xb31 Multimedia Projector Logo
483 people viewed this question
Seeker5211
Seeker5211
