Question about Panasonic DMR-E55 DVD Recorder
Self check Hi when i turn on the machine all i get is self check i have stripped the machine down disconnected the hard drive also DVD cleaned everything with isopropanol alchol everything i have tried has failed.
  • 185 Answers
Unfortunately, none of that will fix your machine, as this is a common fault with these units.
Fortunately though, it can be fixed.
In 99% of cases this is caused by a faulty regulator on the main power board.
The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance.
Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers.
Disconnect your DMR E55 from the power source and remove the lid. Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet.
Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little tricky but it's easy enough if you take care. Refit all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, Your DMR E55 will no longer repeatedly self check and will operate correctly.
Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
If anyone tells you the laser is shot or the drive needs replacing, take absolutely no notice of them because they don't know what they are talking about. The above solution WILL fix your machine if you follow the instructions correctly.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck
Posted on May 23, 2008
When I turn on my emachines t3265 desktop computer, it freezes at the logo, and does not proceed to Windows so I can log on. What is the likely problem, and how can I fix it?
Turn it on.
Hit the ESCAPE (or TAB) key to replace that colourful logo with the technical details of the computer's POST (Power On Self Test) messages. Look for any messages, such as "unable to boot from disk drive" or "disk-drive not detected". Also, remove any CD/DVD media from the CD/DVD drive. Also, remove any 3.5-inch diskette, and disconnect any USB memory-sticks BEFORE you turn it on.
Jul 18, 2011 | E-Machines T3265 PC Desktop
The self cleaning oven is not working. The fan in the back of the oven turns very slowly. the door locks briefly and then unlocks and everything shuts off.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Jenn-Air W30400P Stainless Steel Electric...
Have a Toshiba LAptop Model A215-S7413 and Overheats and turns off. How can I fix it or open it to clean the Dusty Fan on the Bottom? Thanks, AUgie
Once there is no proper vent , the laptop will go off due to over heating, try to always place the laptop in a position where breeze can be reaching the panel from underneath where the fan is.
To disassemble the laptop, follow the steps below:
Turn the laptop over and remove the battery and the CD/DVD-ROM drive.
Remove two screws securing the laptop memory cover and remove it.
Remove two screws securing the laptop hard drive.
Remove the laptop memory module.
Slide the hard drive to the right to disconnect it from the system board and remove the hard drive.
Remove all marked screws on the bottom of the laptop.
Insert a sharp object under the keyboard securing strip and carefully start lifting it up. Continue removing the strip with your fingers.
Be very careful with the strip because it has a control board attached to it.
It might take some time to remove the keyboard strip.
Remove all the screws around the lower bottom and you will have direct access to the fan.
Reverse the process to reassemble the laptop back together.
Take care and good luck
Dec 02, 2010 | Toshiba Computers & Internet
Hi my computer is playing up when i turn it on it says PXE-E61: MEDIA TEST FALURE. CHECK CABLE, but all cables are good. also when i scanned it using the dianostic tool it says error code: BIOHD-8 AND...
Disconnect the Floppy, CD/DVD and any other Drive you have connected and boot the machine. If the machine boots shut it down and connect the disconnected devices 1 at a time until you have it isolated. If the Computer doesn't boot and you still get the same fault then your hard drive has faulted try a different drive.
Jul 12, 2010 | HP dx2250 Monitor Personal computer AMD...
I have a dimension 8400, I recently upgraded my graphics card. Followed the instructions, blew out the computer of dust bunnies, inserted the new card, tured on the power, machine went from start screen to...
check the power cable and ide/sata cable connecting the hard drive to the motherboard maybe they are just disconnected, if the unit is working properly before you cleaned it, or does the unit detect the hard drive and cd/dvd drive during power on self test, if yes then you do need to re install windows, if you do not have an xp cd then you just have to purchased a genuine copy if you want to troubleshoot it by your self, or just take to it to comp. tech save trouble and lost of your time
Nov 24, 2009 | Dell Dimension 8400 PC Desktop
The xbox leeps saying play dvd when i put a game
this could mean your laser is on its way out, but it could also mean it
needs cleaning. the best way to clean is to strip the machine down. strip
the dvd drive down and get a cotton earbud.
spit on the earbud and very gently wipe the laser eye clockwise but dont
press on too hard, very gently.
also get a clean paintbrush and give the drive casings a good clean.
this might help. there is also something else you can try and thats
something called asjusting the 'pots', this is a bit complicated for
anyone not used to the process but i do have a guide if you want to have
a go yourself. what this does is adjust the laser power so its a full
again just like it was when you first bought it. (thats the easy
explanation).
regards
linda
xboxrepairkit
Oct 06, 2009 | Microsoft Xbox 360 Console
My xbox won't read disc just say's open tray.
It sounds like the DVD drive has failed unfortunately. You are going to want to call Microsoft at 1-800-4-My-Xbox for a replacement.
Oct 05, 2009 | Microsoft Xbox 360 Console
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
Panasonic DVD recorder
A self-check for these models can sometimes last for 3-7min's (sometimes longer) depending on how much recorded data is on your hard drive. Plus it checks all unrecorded space on your hard drive as well. Don't forget that it must check 200Gig. If it self checks for longer than 20-30mins turn off at the wall and let cool down. Try again in an hour or so and it should rectify itself. If it continues to self-check for longer than 20-30mins refer your machine to an authorized technition
Nov 28, 2007 | Panasonic DMR-E80H DVD Recorder
Computer will not turn on
The only things that can do this are: A card failure, a hard drive failure, Motherboard faiulre, A Power Supply failure, Faulty RAM. To toubleshoot.. disconnect Hard Dive, CD/DVD remove any & all cards, see if it boots,if it does, add the Hard Drive, reboot, then add the CD/DVD, reboot, then replace A card, reboot & so on... until ya find the faulty component, that stops it. If it doesn't remove ram & see if it powers up, it will NOT boot. If it doesn't ya PSU is most probably faulty. If it does ya RAM/motherboard is faulty. So basically strip it down see if it powers up. than add things one at a time to find the culprit.. then replace the ofending item.
Aug 06, 2007 | HP Compaq Ethernet Switch
Panasonic DMR-E55 DVD Recorder Logo
201 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
