Question about Coby DVD-224 DVD Player
Dvd problems my dvd won't open or close
HI, CAN YOU HEAR A WHIRRING SOUND ? IF SO, THREE CENT RUBBER BAND/DRIVE BELT IS BROKEN. COBY DOES NOT SUPPLY REPLACEMENT PARTS. I'M SEARCHING. CAN CONTACT ME @ SPORT_MODEL1@MSN.COM
I KNOW, I DON'T WANT TO TRASH CAN AN OTHERWISE OPERATING UNIT. I WON'T BUY "COBY" AGAIN, ONLY BRAND NAME WITH REPLACEMENT PARTS.
MR. ED
ATLANTA
Posted on Jul 01, 2008
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
Problem with the tray.it is not working properly and cant come out
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual
God bless you
Sep 27, 2012 | Philips DVP-3005 DVD Player
Problem with the dvd tray
God bless you
Sep 27, 2012 | Televison & Video
Portable DVD player won't recognize door is closed.
My guess would be that the switch inside that the tray hits to tell the dvd player it's closed is broken.
Aug 23, 2012 | Philips portable dvd player phillips...
DVD player is broken and won't open and I have a disc stuck in there
you have 3 alternatives for open:
1) with the button eject or close/open
2) remote control. button open/close or eject
3) with small knife pull out the carrousel for to bring the disk, with carefully.unppluged the power cord.
otherwise you must go to the repair shop TV for fix it
God bless you
Jul 21, 2012 | Philips Magnavox MDV453 DVD Player
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Feb 27, 2012 | Sony DVP-NC600 Multi-disc DVD Player
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
I have a bush dvd2039 and have put a dvd in and it won,t play and open and close won,t work either, have rebooted, unplugged and plugged back in and checked cables etc still nothing can you help please?
i take it your talking about a pc dvd burner if its not opening or closing i wouls say the cog/ruber band has broken you need to replace the driver (dvd burner)
Sep 21, 2010 | Bush DVD2038 DVD Player
Coby DVD-224 DVD Player Logo
111 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
