Buying a Laptop
Finding a laptop with this specifications THE BEST PRICE 250GB HD 3GB DDR2 Dvd recorder, Screen Size 15.4", Media Slot, Infrared Port/ blutooth, WiIFi, Web came, wireless connection @ somewhere $600 $800.....
  • Mihil May 22, 2008
  • crabbypup May 11, 2010
    "trtjdh" what is that??? as for the specs, try searching on google for all the things you want in it. example:
    250GB HD 3GB DDR2 Dvd recorder 15.4" lcd Infrared bluetooth wifi webcam $
    see what it comes up with and for what price. also, wireless and wifi are the same thing!! and the media slot is called an sd cardslot. (if you were looking for that) or a pcmcia card(usually not needed)
    Problem Solver:
  • 15 Answers
Posted on Aug 01, 2009
Increase size of hard drive
It might be able to be done but the best way it to get a external usb hard drive. If your system will let you. I don't think you can put another HD in it because the software that makes your system run is on the orig. one no way to transfer from one to another with out a high price HD copier.
Feb 19, 2015 | Panasonic Dmr-XW380 Dvd Recorder
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
Reset password, recover back to factory restore point
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Dec 02, 2012 | Toshiba Satellite C655-S5132 Laptop...
Can you tell me where the sodimm slots are located on a Advent 6551 laptop
Advent 6551 Laptop Specification CPU Intel Celeron Dual Core T1600 (1.66GHz) BIOS Phoenix BIOS. Press F2 to enter Chipset Intel GL40 Express Memory 1GB DDR2 PC2-6400 800MHz SODIMM (2 memory slots. Max 4GB) Hard Drive 160GB CD Drive DVD±RW Screen 17" Widescreen TFT (native resolution 1440x900) Video Card Integrated Intel GL40 Express Chipset Family Webcam Built in Sound Card Realtek ALC888 High Definition Audio Network Card Realtek 8139 / 810X (Onboard)
MSI MN54G 802.11bg Wireless G Mini PCI Card (MS-6877) Ports 1x Headphone
1x Line-in
1x Microphone
1x Expresscard slot
1x Card Reader
2x USB 2.0
1x Kensington Lock
1x LAN
1x eSATA *
1x DVI Battery U40-3S3700-B1Y1 (11.1v 3700mAh) Size 27.8 x 287 x 402mm (HxWxD) Weight 3.4kg Colour Black Made By F71IL1 * The eSATA port also doubles up as a 3rd USB port.
Your laptop should have been supplied with a Utility CD which contains a copy of the user manual and all the drivers. There is also a copy of the drivers on the laptop itself, you can find it by browsing to the c:\applications\drivers folder. Finally you can download some of them from The Tech Guys website.
The Wireless LAN card uses a Ralink RT72 chipset so if you're struggling to find drivers then the "USB(RT257x/RT2671)" ones on the Ralink site should work -
Memory Upgrades This laptop has two memory slots. One slot is accessed by removing the cover underneath the laptop (see the "Bottom of Laptop" section below)
Jan 20, 2011 | Computers & Internet
Plz send the this laptop zenuan prizes and send this configrution i purchase on 14" tosiba laptop
Our Toshiba review unit had the following specifications:
  • Intel Core 2 Duo T8100 2.1GHz processor
  • Intel X3100 Integrated Graphics
  • 2GB RAM DDR2
  • 160GB (5400 rpm) hard drive
  • 15.4" WXGA 1280x800 screen
  • Intel PRO/Wireless 3945ABG (802.11a/b/g)
  • 10/100 Ethernet LAN
  • Modem port
  • VGA-15 pin
  • DVD-SuperMulti drive (+/-R double layer) supporting up to 11 formats
  • ExpressCard Slot
  • SDCard Slot
  • 3x USB 2.0
  • Headphone and microphone jack
  • webcam
  • Battery: 6-cell (4800mAh) Lithium Ion battery
  • Weight: 5.7lbs
  • Starting price: $949(about 40000 rupees)
The Satellite Pro L300 didn't have any problems running multiple programs or multi-tasking jobs with its Core 2 Duo 2.1GHz processor and 160GB hard drive. I could check email, open documents and surf the Web without any lag. The benchmarks are average and overall the L300 did good on its PCMark05 score compared to other notebooks in the same category. I am sure the fact it is running Windows XP instead of Vista helps out this business savvy notebook as well.
wPrime is a program that forces the processor to do recursive mathematical calculations, the advantage of this program is that it is multi-threaded and can use both processor cores at once, thereby giving more accurate benchmarking measurements than Super Pi.
Dec 17, 2010 | Toshiba Satellite Pro L300 Notebook
Upgrade RAM
DDR 1 - 1 GB costs around Rs 1500 DDR 2 - 1 Gb costs around Rs 1200 DDR 2 - 2 Gb costs around Rs 2200
I just upgraded my system to 2 Gb ddr2.
You can order it on ebay.
Mar 29, 2010 | Lenovo 3000 Y410 Laptop
Looking for specifications on sony vaio pcg-3c2l
  • Sony VAIO VGN-CS115J/R Core 2 Duo T5800 2.0 GHz 14.1-inch Widescreen Notebook
  • General Features:
  • Color: Sangria Red
  • Microsoft Windows Vista Home Premium 64-bit pre-installed w/COA
  • Intel Core 2 Duo T5800 2.0 GHz processor
  • Intel Centrino Processor Technology
  • 4 GB PC2-6400 DDR2 SDRAM (4 GB maximum supported)
  • 250 GB Serial ATA hard drive
  • DVD±RW Double Layer Drive
  • Mobile Intel Graphics Media Accelerator 4500MHD with Intel Clear Video Technology with Total Available Graphics Memory of 1750 MB (max.)
  • Built-in 1.3 megapixel MOTION EYE camera and microphone
  • Intel High Definition Audio with built-in speakers
  • Integrated V.92/V.90 Modem
  • 10Base-T/100Base-TX Ethernet
  • Intel WiFi Link 5100AGN (802.11a/b/g/n) Wireless LAN
  • Integrated Stereo A2DP Bluetooth Technology
  • Keyboard with Touchpad
  • Action Buttons: Play/ Pause/ Stop, AV Mode, Mute, Volume-/+, Capture, WLAN on/off
  • 14.1-inch Widescreen display with XBRITE-ECO Technology (1280 x 800)
  • MultiMedia Card Slots:
  • Memory Stick Pro Media slot (Standard/Duo) with MagicGate functionality
  • Secure Digital media slot
  • Expansion slots:
  • ExpressCard/34 slot
  • I/O ports:
  • Three (3) USB 2.0 ports
  • Headphone jack
  • Microphone input
  • One (1) 15-pin VGA port
  • One (1) i.LINK IEEE 1394 FireWire port
  • RJ-45 Ethernet port
  • RJ-11 Modem port
  • Regulatory Approvals:
  • FCC
  • cULus
This information can be found on
Happy New Year!
Feedback is appreciated!
Dec 31, 2009 | Sony VAIO Notebook
What is the minimum spec I need when buying a laptop to be used mainly for viewing tv
99% of laptops (not netbooks, IE: under 14" screen size) are able to view TV with.
However the obvious thing needed it a TV tuner (either internally in the laptop, an expansion card, or USB tuner)
Nov 23, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
David Payne
David Payne
