Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Stanton S -650
Channel 2 out of the CD player is producing bad audio signal.Sounds like blown speakers. Please advise
  • 3 Answers
Make sure that the "line/phono" switch on the back of the unit is set to "line", or your output signal will sound distorted.
Posted on Jul 15, 2008
No center channel sound on my Yamaha receiver
Is the center channel amp blown? How about checking the center channel input wire for signal?
Jan 06, 2017 | Yamaha Audio Players & Recorders
Why do my subwoofers not work when connected to an amplifier that is powered?
The bus connection is actually not an RCA looks very, similar i think if you look at it it will say IN. as far as i remember its an input for like a CD changer. Run a Y splitter on one of the other RCA out put, split the signal and run one to your bass amp. it does not affect the voltage in the RCA signal. i think your amp is trying to send a signal instead of receiving one.
Apr 11, 2017 | Sony CDX-GT510 CD Player
Is it possible to connect two jacks simulteanously to a speaker like S115 or SW118 coming from 2 different channels of a power amplifier like P5000S' please advise thanks
the s115 and p5000s are power matched for a single channel.
IE - the s115 is rated at 500W and the p5000s is 500W PER CHANNEL.
If you're trying to drive a left/right signal into a single speaker, you need to mix the left right signals together at the input side, and put the mix into a single channel of the amp, and then into the speaker from that one channel.
The other option is to have 2 s115's - one on each channel.
Mar 25, 2011 | Audio Players & Recorders
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
May 09, 2010 | Stanton T.120 Turntable
I have a VR 615 receiver. All 6 surround sound
It all depends on the processing the receiver is doing when recreating the sound. Change the surround mode to Dolby Digital or THX if it's on there. When it is receiving a Left/Right signal only, it does some processing but pretty much spits it out of all the speakers, fronts being the loudest. That's why you always hear them. When it is getting a Digital signal, the receiver does a much better job of processing the audio to the correct speaker, but unless there is a lot of background noise, there might not be any signal going to the speaker.
Also, check to make sure that the "size" of the speaker on the rear channels is set correctly. There is a setting on most receivers to tell the receiver how big the speaker is on that channel. This sets the power level on the output to accomodate the size of the speaker.
Oct 25, 2009 | Kenwood Audio Players & Recorders
Pioneer avic n3 doesn't play audio, but has button sounds
There is a built-in speaker for those tones inside the unit.
Seems as if your internal amplifier IS blown. It is probably cheaper - and will sound better to install a cheap 2 or 4 channel amplifier anyway.
The head units BOAST 50W per channel... but that is PEAK power. Most actually only produce 10-15W rms.
Replacing an output on the head unit will run you approximately $75 for the first... and $20 each additional. (up to 4)
You can get a great class a/b 2 or 4 channel amplifier for that price with built in crossovers and your sound will be 100x better!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | Pioneer AVIC-N3 Car DVD Player
JVC KDSH55 REAR SPEAKER OUTPUTS BLOWN?
well it sounds like u may have blown the channel or your amp was powering your rear speakers
Dec 20, 2008 | JVC KD-SH55 CD Player
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
117 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
