Question about Kenwood Audio Players & Recorders
Amplifier overheat`s afet a couple minutes and shuts off....but still keeps on getting warmer and warmer till it's boiling???
    Novelist:
    Champion:
  • 236 Answers
Have your speakers checked for possible impedance chnage, probably shorted one of the coils. otherwise if this is a new set then possible that you have a mismatched speaker impedance, using a speaker set with lower impedance than the minimum required. specially if you're using multi channel amplifier. shutting off is a protection, that makes your system safe for damage
Posted on May 22, 2008
Why is my freezer motor getting very hot
Normal operation. If it overheats due to excessive amperage the clixon will shut it down till it cools. Those motors are normally cooled by the cold gas returning from the evaporator. If freezer temps are where they should be then it is not a problem. If freezer is warmer due to low freon the motor will run hotter.
Jul 25, 2015 | Refrigerators
How do food warmers work?
Usually food warmers consist in trays of food sitting in a bath of boiling hot water. The hot water heats up the tray, keeping the food warm.
Most domestic food warmers are electrically powered.
Dec 30, 2013 | Kitchen Appliances - Others
Auto shut off hot
A faulty transistor or IC that has failed, it probably overheats before any other device. You should shut the amp down when it happens, then feel carefully around for the hottest part. I would replace that. Or you can power the amp back up wait till it acts up, then spray that hot part with Servisol Freezer spray. If it comes back on, then you know it's faulty. If not try another part, with the spray, only one at a time.
Nov 18, 2013 | Peavey Audio Players & Recorders
I have an Alpine M500 mono amp that works great, until you turn up the volume. I can adjust the bass down at the head unit, but at higher bass the amp shuts off. And then comes back on after a couple...
I don't think either, I believe your running theamp load too low with too low an ohm speakers and this cases the amp to produce more power but not stable and it overheats and the thermal protection cuts the amp off when the temp gets too hot to prevent damage.. Make sure your speakers depending on how they are wired do not exceed the amps load rating
Oct 26, 2009 | Alpine MRD-M500 Car Audio Amplifier
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
I have problem with my mono amplifier
Amplifiers have thermal protection. They will typically shut down at ~180F. If your amp is shutting down after running it hard for 20-30 minutes, you may not have the correct load impedance (speakers wired incorrectly).
If it overheats as soon as it's switched on (no audio), the amp may be in need of repair.
Jun 21, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Help its aggrovating!!!
Maybe the cooling system has become blocked up with dust and such? That's what happens with my laptop, I have to take it apart every couple months and clean out the cooling system or it overheats and shuts off.
Aug 17, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Car amp problem
make sure the front left wires arent shorting out if they are they could be causing the amp to overheat and shut down till`s its cooled ehough to restart
Apr 01, 2007 | Alpine MRV-F540 Car Audio Amplifier
153 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
