Jenn-Air JGR8850 Gas Kitchen Range Logo
Posted on Sep 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gas burner is working but clikcing like it wants to ignite, however it has already ignited. What can we do to make it stop without having to turn off the gas to the whole stove
Anonymous
Level 3:
  • Jenn-Air Master 43,501 Answers
  • Posted on Sep 26, 2010
Anonymous
Jenn-Air Master
Level 3:
Answers
43501
Questions
0
Helped
10838192
Points
101584
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
The electric igniters for the stove burners stopped working. All four stopped at the same time.
If all 4 stopped working at the same time, the problem is with the spark modulator.
If the igniter is working on several of the burners but not on another, (or any variation), the problem is with the igniter wiring harness.
By design, the igniter for each burner is daisy chained in the wiring harness such that if one goes, the others will still work.
Svd48600w clock out can't turn on oven, or down draft fan
see this causes and fix it: God bless you
IGNITER
If your gas oven is not heating, the igniter is the most likely the cause. This is a simple gas oven repair. To check the igniter, remove the storage drawer and the bottom of the oven (only if you are working on the bake burner). Now turn on the oven and observe, from a distance, the burner that is not heating. In a minute or so the igniter should glow red. If not, unplug power from oven. Then unplug the igniter and using your ohmmeter ,check to see if you have continuity between the two wires going to the igniter. If you don't have continuity, replace the igniter. If you do have continuity the igniter is still the likely problem, If you turned on the oven and the igniter did glow red, the igniter still is most likely the problem. This video will walk you through properly testing an oven igniter. You have to have an amp meter to check for sure, but I would not suggest buying an amp meter just to check this because 99% of the time its going to be the igniter. So I suggest just replacing the igniter. For those of you that already have an amp meter, clamp the amp meter on one of the wires going to the igniter then turn on the oven. If your igniter is round, the amp meter should read 2.6 to 3.0. If you have a flat igniter then the amp meter should read 3.3 to 3.6. If the amps are not in this range, the gas valve will not open to release gas to the igniter. To repair this, replace the igniter.
BURNER CLOGGED
This is another simple gas oven repair and it's one thing you may need to check before you change any parts. The burner has a lot of small holes that connect the flame all the way around the burner. If one of these small holes is stopped up, the burner will not light properly. To repair this, simply use a large needle or thin wire to clean each hole out. Note that this is not a very common problem but if this does fix your oven, it will save you a lot of money.
GAS VALVE
If your gas oven is not heating, the gas valve may be your problem. If your igniter isn't bad then the gas valve is the problem. This is a very uncommon failure in most ovens. But this is not a simple gas oven repair and it's best if this is changed by a professional because if the gas valve leaks it can be a major fire hazard and you have to adjust the valve to the kind of gas you are using.
Main Control
This is the last thing to check. If you have no power to the igniter when the oven is turned on the main control is the likely problem. On glowbar style igniters if you have no reading and there is continuity of the igniter replace the main control. On ovens with electronic igniters (these are the ones that click) these ovens have a separate spark control module that sends the power to the igniter. This can be difficult to check but in general if you have no power reaching the igniter the spark module or igniter module (there are many different names for this part) would need replacing.
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 • Cooktops
3helpful
2answers
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
3answers
Swooshing sound in oven when burner ignites
the valve your talking about with the two wires on it is the safety valve and should not let gas in without the ignightor being on sounds like its leaking i recommend shutting the gas off till the valve is replaced there is no piolet light on theese ranges
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
