Mp3 was working, then it stopped
After adding new songs to my mp3 player I unhooked it and took it into my room.It said that it was still connected to the USB although everything was completely unhooked.To try and fix the problem I hooked it back up think that maybe the songs hadn't completely finished downloading to my mp3.It then wouldn't show any connection at all.I unhooked everything again and my mp3 player wouldn't turn on at all. NO SE PUEDE PRODUCIR
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 22, 2008
How to add songs to Philips SA2310 GoGear Mp3 Player 1GB MP3 Player from pc. does it needs any software??? where can i get that software?????
U DO NOT REQUIRE ANY SOFTWARE TO ADD SONGS TO UR PHILLIPS MP3 PLAYER. JUST USE UR USB CABLE TO CONNECT WITH THE PC. THEN U SEE ONE DRIVE NAMED REMOVABLE DRIVE COMES IN MY COMPUTER. JUST DOUBLE CLICK ON IT AND ADD MP3 SONGS AND THE SONGS ARE ADDED TO MP3 PLAYER. ENJOY THE SONGS IN PHILIPS MP3 PLAYER. GREAT SOUND.....
Sep 15, 2009 | Philips SA2310 GoGear Mp3 Player
Deleting songs on the mp3 player
you can delete songs by connecting to your Pc. simply plug your mp3 device to PC USB slot. select the newly found drive from "My computer" /open the folder of the said drive and select the song you want to delete, right click the mouse and select "delete"
Jan 15, 2009 | Nextar MA933A MP3 Player
My mp3 took songs off instead of adding.
Hello, I probably can help.
If its *full* its do to Filesystem Partially Corruption.
*BACKUP* all your songs. Then right click the usb device, format, than format in FAT format NOT FAT32 or NOT NTFS! THESE WILL RENDER YOUR DEVICE USELESS! Reload your songs and they should be good-to-go. If not i suggest contacting GPX
www.gpx.com
Nov 30, 2008 | GPX MW3836 MP3 Player
Help
goto comp.
hook up usb connector to mp3
goto my computer
find the new drive and letter that was just added
open it
select your songs you want to delete and hit delete
May 09, 2008 | Samsung YP-K3 MP3 Player
Why wont my Sansa get songs???
You may have to install Musicmatch and add songs through the portable device menu. It worked for me. Good luck.
Oct 28, 2007 | SanDisk Sansa m230 MP3 Player
New songs can't be opened
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Oct 11, 2007 | Insignia IN-MP3256 MP3 Player
Mp3 player displays "no files"
It is likely that the files loaded are not true MP3, therefore the PC -which can cope with WAV and other formats will play them but the player that read only MP3 cannot. Are you sure the files loaded are truly MP3?
Jul 07, 2007 | Lexar LDP-400 MP3 Player
Why cant i put songs i removed back on
This player can only handle songs that are in a specific bit rate - lower it to the rate suggested in your product specs. Go to RCA's website if you have lost the documentation. Corrupt file systems can usually be solved with a firmware upgrade (also at RCA's website), but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 28, 2007 | RCA Lyra RD2763 MP3 Player
Insignia 4MB MP3/video player
File allocation table on your player is corrupt. try to use the following method to transfer files from your player to your c drive... else... all is gone...
You can use Windows Explorer to transfer files to and from your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your files to/from your c drive to the new drive for your player. You'll notice that when you use Windows explorer to delete the files on your new drive for your player that it doesnt remove them from your Music Library on your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Mar 13, 2007 | Insignia IN-MP3256 MP3 Player
Mp3 player
Load the Philips software onto your computer. You have to load the songs onto the player using WMP (Windows Media Player) 8 or 9. Connect the player using the USB cable. Run the Philips Go Gear Digital Audio Player software. Upgrade the firmware. This will format the player and erase everything you have done so far. Start WMP. Click on the Synch tab.It will have 2 window panes. In the right side, at the top, there is a drop list. Select the player from the list. Now create a synch list by clicking on edit playlist. Once you have added the songs, click Start Synch. That's all there is to it. Ian
Feb 02, 2007 | Philips GoGear SA261 MP3 Player
46 people viewed this question
 Grubhead
Grubhead
