Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi Widescreen Ultra vision 42" TV Digital - Model # 42V715 cost $ 2300.00 new in 2004. When we turn it on, it will run for a short time and then shut off, the screen goes black and later turns back on. Thenstarts this all over again. We have heard about a company who customize and "designed" a defect in specific TV's to make it purposely stop working after 4-6 years. Was not sure if our TV was one of these prize TV's? $ 2400.00 for 6 yrs of use...dont think we will ever buy from this company again!!!!
SOURCE:
  • 326 Answers
SOURCE: hitachi 42 inch ultra vision has double image
it is just a convergence problem which makes the image look doubled.it can be repaired by any good local tv technician for approx 75 to 80 dollars.nothing much to worry.
Posted on Dec 28, 2008
freetek
  • 5569 Answers
SOURCE: Hitachi Ultra Vision 61UWX10BB Will not power up Red led flashes
Your repair didn't address the failure. It is much more likely (in the absence of video and sound) that the power supply has failed.
The items you replaced affect convergence and have nothing to do with the audio section or the set's ability to receive signal. The power supply failure will diasable everything.
Look for a separate board with larger-than-average components, some cylindrical (capacitors), some block-shaped (chokes and transformers). And you may be able to recognize its relationship to the AC input line.
Locate the assembly number which may be on a paper label or just printed in ink on the board; any that appear to have been part of the etched traces will be only the empty board number, not the assembly.
Removing and replacing this assembly can be done by most everyone using a little common sense and just plugging in the connectors where they belong. Call your Hitachi service center and ask about potential repair or replacement costs. If you can score a new board, don't throw away the old one since the new board will be as crappy as the original. This way, you will have time and opportunity to find an independent reapir service for these and have a spare on hand for . . . sorry, the next failure. These things aren't 'your father's TV', they die much more often.
Posted on May 25, 2009
  • 72 Answers
SOURCE: hitachi ultravision 2005 turns on for about 5
could be shoted convergence ICs
Posted on Jun 07, 2009
SOURCE: hitachi tv **** and people should just stop buying them.
Oh yeah I heard something light that. but yeah it's most probable a defective ballast lot of mitsubishis have had this issue, I'm gonna read more about the lawsuit just for the 411
Posted on Jun 30, 2009
  • 30 Answers
SOURCE: hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Posted on Aug 09, 2009
Hitachi HD monitor 42 inch ultra vision digital has bad colors is it possible to have a bad converter ?
its a projection,it is going to cost as much to fix as a used lcd hdtv!,turn it into a fish tank
May 11, 2015 | Hitachi 50VF820 Projection TV
Hitachi
Mine did that and the red light was flashing it was the lamp. Best place to get one is ebay
Aug 03, 2012 | Hitachi 42V715 42" HDTV
Yellow to green tent screen to hitachi tv 42v715
You have some reason to believe it will not?
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
HOPE IT WORKS OUT FOR YOU.
Jun 11, 2012 | Hitachi 42V715 42" HDTV
I need Tv manual for HITACHI 19HD TV Model Number -L19DP03UA
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Apr 11, 2011 | Hitachi 42V715 42" HDTV
Possible to download 42v715 manuel on my laptop?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Feb 04, 2011 | Hitachi 42V715 42" HDTV
Power light is on, temp light blinks, and lamp light blinks, no picture.
Its possible that your lamp is bad, or you have not closed the lamp cover properly. If you don't close it, the sensor will tell the TV not to turn on.
Feb 04, 2010 | Hitachi 42V715 42" HDTV
Yellow spots
I have been told by a local repair person that Hitachi might replace the light engine at no cost because it is such a big issue... has anyone hear about this... I am going to contact them directly also.
Sep 08, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi 42 inch ultra vision has double image
Dec 01, 2008 | Hitachi 60V500 60" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
