Question about Refrigerators
Kenmore 52603100 refrigerator was icing up, now has stopped cooling!
My refrigerator had been icing up down below in the freezer. It appeared that something back in the cooling coil area had been causing water to run down into the the bottom of the freezer but instead of running out of the bottom it has been filling up in the bottom and turning to ice. I cleaned it all out once and cleared the drain hole at the bottom but after a few days it started doing it again. Now today it just stopped cooling all together and I don't even hear the compressor or fan running.
  • jdtenunder Apr 04, 2009
    i have the same problem. and my lower drawer is freezing all of my vegies and pissing off my wife. we already spent to much money on a so called repair man. where exactly is that sensore that needs to be well inside the freezor
Here is your problem:
There are two temperature sensor wires; one should be routed around the vent on the upper left corner of the "ceiling" of the fridge. It will route inside the plastic cover in the back upper corner.
The second one is critical. It originates inside the cover and must pass through the wall of the fridge into the freezer and rest just inside a hole in the rectangle that passes through from one side to the other. If the very tip of this sensor is not well inside the freezer, the system will think the freezer is too warm, never turn off and the lovours inside the plastic housing described above will jam with ice and get stuck. This piece will have to be replaced but will continue to freeze and break until the sensors are placed in the correct locations. Don't ask me how I know all this.
Good luck.
Posted on Oct 15, 2008
Why would the top stop working but the freezer still operate?
the air damper apparently has failed or that area in the refrigerator is too full and air can not get thru .
Nov 27, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
Frost and ice is building up on the right side vent in the back of the freezer. What would cause this?
Its defrost issue.The defrost thermostat,timer and defrost assembly. Any of the one can be faulty causing these.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
These will help.
Thanks,.
253.57189601 parts list
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Kenmore Refrigerators
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
I'm have a Kenmore top Freezer that the Ice box below is not getting cool and The freezer is getting to cool. Please help.
You probably have an issue with the "defrost thermostat" or "defrost
heater(s)". Contact an appliance service company.
Feb 17, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Refrigerators Logo
434 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
