Question about Panasonic DMR-E55 DVD Recorder
Self check hi when i turn on the unit DMRE85H all i get is Self Check it just goes on and on forever any idea's geoffrico
  • geoffrico May 22, 2008
    Hi no good
    Hi continouse self check it just goes on forever HELP
  • 3,037 Answers
A lot of these devices have this problem, the hard drive probably needs to be replaced in order to fix it, unplugging it doesn't help and will just continue to put it in self check. If still under warranty, replace it or you are just better off getting a new one. Either way you should call Panasonic about it and see what they will do for you, whether give you a discount or what. Let me know if you have any further questions but no matter what something will need to be replaced whether the harddrive or the whole device. The software is designed to work on this specific device so Panasonic is the only one who can really help you fix this. Good luck and I would be glad to do anything else that you may need.
Have a good day
Posted on May 22, 2008
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Did you contact the manufacturer about this and confirm what I said
    if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    Genius:
  • 3,587 Answers
Ok..first step..disconnect all input and output cables, so that the unit is simply like it was from the manufacturer when brand new..
than plug it in, and try that again..if not, then we'll proceed to step two
    President:
  • 2,712 Answers
Try a hard reset: Unplug the recorder from the power socket and TV, wait about 5 minutes and replug into the power socket and TV.
Please try that first and let me know how it goes..
  • Swilin Sampson
    Swilin Sampson May 22, 2008
    This is a common problem with this device.
    Try this:
    To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip
    Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
    If that doesnt work, you can try to Download the Upgrade File
    . Extract the zip file to a folder in your PC and burn it onto a CD. This should be a regular DATA CD. So select the appropriate setting in the burning software. I assume the unit observes the filename's extension and
    then validates that it is an upgrade file. I think it also compares the CD
    version with the currently installed version and does not do the upgrade if the
    one on the CD is the same or an older version. You simply put the disk in the
    unit and it will take it from there. It doesn't take long. It opens the DVD
    drive at one point. Just take the CD out and close the drive. After a while,
    the unit shuts off. You then power the unit up again and you should be good to go.
    If that does not work, you may have to change the power supply regulator and add some extra heat sinking. You only have
    1/4 of an inch between the top of the heat sink and the bottom of the
    HDD carrier but adding a piece of aluminium sheet to soak away any
    excess heat may mean you only have to replace it once.
    It could also be due to due to RAM drive failing, in which case this will have to be replaced.
    If all else fails, try calling Panasonic customer care at 08705357357.
    Hope that helps! Should you have any further questions,
    please post them here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
Turns off blinks 6 times and turns off blinks eight times
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.good luck
shaun
Aug 22, 2009 | Sony Televison & Video
When I switch on the recorder goes into SELF Check for 10 to 20 minutes
Try replacing bad capacitors on the power supplycard. See http://vassfamily.net/projects/DMRE85H/dmre85h.html
Good luck.
Alsofor those interested, I found the "commands" listed onhttp://www.dxcc.com/dmr-e85h.htm useful when operating the DMR-e85h tocorrect problems.
Jul 24, 2009 | Panasonic DMR-E85H DVD Recorder
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
A/C won't work 03 Acura RSX
General Troubleshooting Information
How to Retrieve a DTC
The Climate Control Unit has a self-diagnosis function. To run the self-diagnosis function, do the following:
1. Turn the ignition switch OFF.
2. Tu rn the fan switch OFF, the temperature control dial to MaxCool (60.F or 18.C), and the mode control dial to Vent.
3, Turn the ignition switch ON (ll),then press and hold the recirculation control switch. Within lO seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times and the A/C indicator comes on, then the self-diagnosis will begin. About 15 seconds later, the self diagnosis will finish and the Ay'C indicator goes off. lf there is any problem in the system after finished self diagnosis, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 1 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and t5), the A/C indicator will blink the DTC. lf no DTCs are found. the indicator will not blink.
d35f123.jpg 695f305.jpg5d11822.jpg Resetting the Self-diagnosis Function
Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions.
Jan 13, 2009 | 2006 Acura RSX
Sony kv-34xbr910 wont turn on
I have sony 34 XBR Tube trinitron HD TV. We are not using the TV because it keep giving us 6 blinks and does not turn on
Apr 26, 2008 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
Feb 03, 2008 | Televison & Video
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
