Question about Lexmark Office Equipment & Supplies
I cannot load the software drivers to my Lexmart X6570 printer. It will make a straight copy but will not print from the computer or scan. I have tried the CD that came with the printer and tried to download the driver from Lexmart website. Nothing is working right now.
  • 27 Answers
Hi is the pc your on xp or vista ?
some printers are not compatible on vista if this is what your using there is however a fix for this go on the net and down load a program called driver genius 2007 pro this will find any driver problems on your pc sys and down load the drivers to fix any problems on you pc complet .
hope this helps ok thanks
Posted on May 22, 2008
My scanner and copier are giving me all black documents. HELP PLEASE.
is it possible the color cartridge is empty? also when you print a document try it this way... press and hold the Crtl button and press "P". so it's "control P" now at the bottom of the left side menu screen you will see a "color" button select Color and then print.
Jan 06, 2015 | Lexmark X6570 All-in-one Inkjet Printer
My printer has new carthridges prints from computer but does not make copies
Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Apr 22, 2014 | HP Photosmart C4400 series
Does the Lexmart 1100 Printer need operating software?
You likely mean LEXMARK. The printer will function without software other than what is in internal to it (firmware). If you want to print from your computer, you will need the print driver installed.
Apr 12, 2013 | Lexmark Color JetPrinter 1100 InkJet
I am having problems connecting to a lexmark X6570 printer using wifi on my laptop, I have windows 7 64 bits
You may need to reset the printer's wireless network adapter first before re-installing the printer driver. Here's How to Reset the Network Settings on the X6570 Series AIO Inkjet Printer.
Also, the printer driver cjb6500en is for 32-bit operating systems. Please visit the Lexmark website at to download and install the correct printer driver for a Windows 7 64-bit ( cjq6500en.exe ). Simply follow the instructions on your computer screen to complete the installation.
Apr 05, 2012 | Lexmark X6570 InkJet Printer
Will not print on iMac desktop
Make sure the Lexmark X6570 printer driver is installed on your iMac desktop. You can download and install the X6570 printer driver by visiting the Lexmark website at Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Aug 10, 2011 | Lexmark X6570 InkJet Printer
I can't scan with my Lexmark 2600m All-In-One Printer. I think there may be missing programs on the computer. When I press the scan button, nothing happens on the printer or the computer. It prints...
Make sure the Lexmark OCR scan software is installed on your computer. The scan software is available on the install disc that came with your printer. If lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 26, 2011 | Lexmark X2600 InkJet Printer
How do i connect to this printer from another laptop without a disc?
If windows will detect the printer, you can probably print, however, you may not be able to communicate with the printer for scanning functions, since the printer uses the Lexmark Imaging program to transfer the scans to the computer. Go to the control panel to ensure, under "printers", that the printer was detected, when you hook it up to computer. Some printers require the software to be installed first, in which case I'm not certain it will function, otherwise.
Try to get a copy of the Imaging program from Best Buy- sometimes they keep copies for such situation.
Good luck, and hope this helps.
May 16, 2011 | Lexmark X6570 InkJet Printer
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Cannot get t180 to talk to the printer Lexmart x6100
check that the driver that is on the cdrom is vista supported and not XP as this will cause problems, the printer that is set at default may not be the lexmark, so check in the printers menu that it is actually listed.
Try here for a driver
Oct 20, 2007 | Acer Aspire™ T180 PC Desktop
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
