Question about Toshiba Televison & Video
Toshiba 32c3500p.. panel lock came up on screen. I turned off tv and now the tv wont turn back on. Standby light is on red.
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
SOURCE: Pioneer SD-532HD5 Projection Screen TV won't turn back on.
The problem is the power supply components over heating. The power supply is on the back side right hand. supply extra cooling via a fan and it will stop shutting down. This is just a cheap and simple fix that wil tie you over for a while. cheers mates.
Posted on Mar 09, 2008
  • 52 Answers
SOURCE: sony wega kdl-l32mrx1 3 yrs
Sounds like somthing is shorted (hence the crackeling sound) and the unit is going into error protection mode causing ot to go back in stand by. The most common problem is bad caps or shorted fets on the power supply. If your good with a meter, you should be able to open the back of the set and find the problem quickly. Or look at the back of the set when you power it on and see if you can find the arching.
Posted on Aug 13, 2008
  • 13 Answers
SOURCE: tv wont turnon afterstandby
LG will sell you a new lamp. It may resolve the problem but just as likely it's the contacts where the lamp unit plugs to the TV. There's a few types of connectors. The early ones are dodgy and cause the problem you describe. A faulty lamp can also cause it though.
Posted on Jun 05, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Tv wont turn on. toshiba 37c3030d
The internal power supply has died. take it to a repair facility.
Aug 13, 2009 | Toshiba 37C3030D 37 in. LCD Television
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Tv wont turn on
Is it plasma , or LCD?
Feb 16, 2008 | iLO 2600 Television
Standby light is on, but power switch does nothing
The FPA (Front Panel Access) lock is on. This allows you to prevent kids from using the set when you are not there and disables the buttons on the front of the TV. The set should turn on with the remote only, and then you can go back into the menu and turn off the FPA, also called child lock.
Aug 04, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
