Question about Sylvania 6413TC 13" TV
Remote Control not working for MW24FM3 Toshiba
Any suggestions how to get a remote control to work for this unit? Everything is original and all of a sudden the remote doesn't work. I've replaced batteries, ensured the remote is the proper distance and the line of sight is clear to the TV... but I get nothing.
Do remotes often go bad? I don't want to replace the remote if it is potentially something with the TV.
Any thoughts? Thanks, Rick Suddenly the remote stopped working on my 13 in TV. But it works on another Sylvania TV in the house that is a 19 in. TV.
  • Megs05 Jun 09, 2008
    I'm having the same problem. The t.v. works. The remote doesn't. I've replaced the batteries, but the little bulb at the head of the remote doesn't even light up when buttons are pushed. Do I need to buy a new remote?
  • 4 Answers
Popa flaggy poo.
Posted on Jul 23, 2008
I cannot get any codes to work for my curtis international tv, using a samsung cablevision remote control.
Do a search function with this remote control. Try to download the user manual to your remote control by internet, for details.
Feb 11, 2013 | Curtis International New Original LED2440A...
When I purchased this remote control a few weeks ago, I programmed it and it worked great! a few weeks later, it stopped working. So, I re-programmed it again. Will I need to re-program this remote control...
I would suggest contacting the Toshiba MR 120's manufacurer or the dealer from whom you bought it. Either one will likely exchange it for one that works if it's discovered that the problem is in the original manufacture, or they will check for programming gliches and fix the ones that exist. Either way, your remote should not be behaving that way, and one would like to think that a quality brand name like Toshiba will stand behind their products.
Feb 21, 2011 | Toshiba MR120 Remote Control
Remote does not work
Remotes devices are heavily depened on it CPU chip,might the CPU chip is shorted and dead the remote is garbage.Tries take the remote aparts,take some Q tips dipping in some rubbing alchahol clean the PCB board and inner rubber layers,wait like about 20 mins. than putting it back together again put in brand new batteries,might get the remote to work again.Not try website like Remotes.com to buy an original or very close to the original remote.
Jan 06, 2011 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
I need to find a replacement remote control. Any
The link below contains the original replacement remote for your unit.
Toshiba SD-4100 Replacement Remote Control
Dec 31, 2009 | Toshiba SD-4100 DVD Player
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
Remote control SENSOR not working
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit www.semenedis.com who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Dec 04, 2008 | Toshiba 32A60 32" TV
Remote control
YES... Get a miracle remote, http://www.miracleremote.com/ for Toshiba and it will operate ALL of the functions like the original including access to the service menus.
Nov 02, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
I have the same problem with my unit. I use the original remote and my Tivo remote. Both stopped working at the same time. Ocassionally they will work for awhile then stop. They always both work or both don't. Therefore it must be the TV; likely the sensor or something connected to it. Sorry I don't have a solution. Guess I need to take it to the shop.
May 07, 2008 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
Sylvania 6413TC 13" TV Logo
102 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
