Question about Kenmore Elite 45986 Front Load Washer
Front loading Automatic Washer kenmore washer
Kenmore elite washer will not spin and drain, follow the direction of cleaning out the drain in bottom. any suggestion of what to do next .
laundry falling behind.
Thanks, ken
  • 3,037 Answers
Most likely the lid switch is the problem, have a look at this and replace it if needed. If not the switch, let me know and I would be glad to let you know what else it may be.
good luck
Posted on May 28, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 28, 2008
    since it isn't spinning you should open up the outer panels and take a look at the motor and belt if the switch isn't the problem
  • Benjamin Patri
    For information on the lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
    1. It can fail internally. It will look fine outside but it won't close the circuit
    2. Or the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
    The lid switch is cheap and very easy to repair.
    To learn how to troubleshoot this switch please visit the below link
    www.applianceaid.com/procedures.html
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    Sergeant:
    Champion:
  • 359 Answers
You need to take the cover off to access the bottom drain. Also pull off the attached hoses to the drain & clean them out, they probably have stuff stuck in them which is blocking the water flow. Same thing happened to me and thats how i fixed it as cleaning out the bottom won't just do if hoses r blocked. Hope this helps
    Genius:
  • 2,035 Answers
Usually you can get it running by cleaning the drain or by clearing a small clothing item from the bottom front area of the tub, behind the rubber gasket. check for any blocked items ................
good luck.........
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loader Washer Doesn't Drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore Elite front load washer, has been beeping with F 02 flashing about 3/4 through the cycle and the door is locked. I have to hold cancel then i select to drain and spin. It then goes to 11 mins...
"F02" is a Long Drain error code. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Feb 24, 2010 | Kenmore Elite 45986 Front Load Washer
Won't finish spin/drain cycle. was beeping and
long drain? remove lower cover on front..3 screws across bottom edge. there is a screw-on cover to a clean out. has a screen in there and may be clogged. prepare for a lot of water..u might lean it back against the wall to limit the mess. clean out is white plastic right up front.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Not draining or spinning
probably not drain hose ..remove screws bottom cover remove clean out port on pump and clean.. after removing as much water as possible from tub
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer doesn't drain or spin
remove bottom panel dip as much water as possible out if possible lean washer backward to keep as much as possible away from pump inlet remove clean out port plug by turning counterclockwise clean debris from pump impeller
Jun 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE front load washer
seems to be a fault design in the doorlocks, fit new lock
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
52 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
