Question about Olympus FE-110 Digital Camera
Green tint to pictures
When I turn the camera on and look through my LCD screen it has a green tint to the whole background. When I take the pictures and print them It has a green tint to the picture
    Genius:
  • 2,985 Answers
This a CCD fault- it should be returned to the Vendor if under warranty or contact Maskers Website
Posted on Aug 29, 2008
Green tint - even background when blue selected
We have usually found it to be the VGA cable connection when the whole screen is tinted. Have you checked the pins in the VGA cord as well to make sure one is not missing or bent.
Apr 18, 2014 | Epson EB-X72 diamond lamp
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Gillight
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
Pentax Optio Rs1000 has a green tint on screen
I have the same problem to.Do u mind to teach me how to fix it?I mean the step to fix the green screen?I have try to change many mode but the reseult is still same.Also i do transfer some of the images that i took to computer but still the image that i took is in green color.Kindly please assist me.
Jun 24, 2012 | Pentax Optio RS1000 Digital Camera
My hp pavillion dv7 1245dx screen has a red tint in the background?
Your lcd screen is bad. It's either the lcd screen or the video card inside the computer, but most likely the screen. You can isolate the problem by connecting an external monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the read and green tint then your video card inside the computer is good but your lcd screen is bad. If the Borrowed monitor displays the same red and green tint then the video card inside the computer is bad.
It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 05, 2012 | HP Computers & Internet
Green tint on picture 60in mitsubishi
Turn the color all the way off---examine the screen to see if black and white or screen green in areas or whole screen.
The other possible issue is tint will not vary enough from green to purple when adjusted.
Two different issues--which do you seem to have?
May 31, 2012 | Mitsubishi WD-60737 60 in. HDTV
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony KP%&HW40 with varying background tinting
YOU HAVE 6 ADJUSTMENT BEHIDE THE SPEAKER SCREEN. THERE ARE TWO SCREWS YOU NEED TO REMOVE. ADJUST JUST THE MIDDLE BOTTOM SLOWLY. IT SHOULD CLEAR YOUR PICTURE. IF IT DOES NOT WORK IT MAYBE YOUR GREEN CRT. THIS TV IS GARBAGE. IM TRYING TO GET 100 PEOPLE CALL SONY APRIL 17,2008 AND GTHEN SEND TGHEM A LETTER AND AFTER CONTACT YOU LOCAL MEDIA FOR THIS DEFECT. SONY HAS TO PAY YOU BACK OR REPLACE THIS TV.
Feb 23, 2008 | Sony KP-57HW40 57" Rear Projection...
Picture is Red Tint (Execpt Menus)
Did you ever find out what it was?
Oct 14, 2007 | Polaroid FLM-3201 Television
Olympus FE-110 Digital Camera Logo
209 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
