Question about Toshiba E-STUDIO 550 Copier
Error code c26 on my Toshiba 550 copier
When i turn on my Toshiba 550 copier, it starts to warm up, but within seconds it goes into error code 26, although I continue to hear the unit warming up.
    Problem Solver:
  • 10 Answers
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
Posted on Jul 16, 2009
    Problem Solver:
  • 3 Answers
Http://www.copytechnet.com/forums/toshiba/14673-e-studio-550-code-c-26-a.html chcck out this page. it may offer some insight. it is a problem in the scanner portion of copier
Posted on Jun 23, 2009
Reset spanner error
There are several error you need to know the sub code by pressing c and 8, frequently you may come across the error code C44,C97,C26
.For C44 the error clearance is "switch on the copier while pressing 0&8 AD will appear enter 400 and press start (print) button and enter "0" and press Interrupt button , switch off and on the machine .If the error code is C97 the main charger to be cleaned in drum unit, If it is C26 you need to check the scanner cable..Hope the anser.
Jun 11, 2014 | Toshiba e-Studio163 Copier
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
Toshiba E-studio 166 error code c26
hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
Mar 07, 2012 | Toshiba e-Studio163 Copier
Tips on C26 code , more info how to fix
[C26] = Peak detection error
Does the exposure lamp light? (Perform the output check in the test mode: 03-267)
If no, Replace the SLG board-->inverter-->exposure lamp.
Oct 07, 2010 | Toshiba E-STUDIO 550 Copier
What is the solution for error code c26 on my toshiba e-studio 550 copier?
Hi how are you i hope you are well this is jack ..my personal ID.. (jack_pak@hotmail.com)
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
Error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
May 12, 2010 | Toshiba e-STUDIO166 Printer
Call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
Oct 06, 2009 | Toshiba E-STUDIO 650 Copier
Help
C26 is a peak detection error (when the copier scans the white reference plate there is an error in the detection)
The most common cause of C26 error is the failure the lens unit which is Toshiba's part number 6LA02100000.
The components that fail on the board are IC1 and IC10.
The board can be repaired, but most commonly it is replaced.
May 05, 2008 | Toshiba E-STUDIO 650 Copier
Help me
A C26 code is a peak detection error on your scanner. You'll have to turn off the copier, remove the glass and CAREFULLY clean the mirrors and exposure lamp on the scanner. That usually takes care of the problem.
Apr 08, 2008 | Toshiba E-STUDIO 650 Copier
745 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
