Question about Jensen JPA285 Car Audio Amplifier
Problems With My Jensen 425 Watt Amp
My Amp was fading in and out it would shut off and then start to turn back on. When i took the panel off of it there was a copasitor that was loose. So i fired up my soldering iron up and fixed it when i hooked it back up in my car i was starting to put my fuseblock in and it started to shoot sparks from the inside wat would that be and how can i fix it
  • Chipmunk2007 May 23, 2008
    I had Put The Capasitor in The Right way and The Amp Was Sparking Inside of It and i had also Made Sure that there was no solder on anything else to be bridged but it was sparking wen i put a new capasitor in today woulkd it that the board is shot
Have you checked your Ground wire connection? It may be grounding in and out. I have had a similar problem and it ended up being the ground wire, I have the same amp, use it on nearly full level/bass works great 0 problems
Posted on Jul 21, 2008
  • 631 Answers
It's normal to see sparks when reinstalling the fuse. But they should only be produced inside the fuse holder when the fuse makes contact with the terminals of the fuse holder.
Did you reinstall the capacitor with the correct polarity? If you installed it backwards, it may have blown out or could be causing other problems.
Did you possibly bridge the connections in the amp when you soldered the camp in?
It's possible that something failed and caused the cap to melt out of the board. The failed component may have caused the fireworks inside the amp.
If you're new to repair and want to lear more, visit the following site. If you have questions, feel free to ask.
Basic Amplifier Repair Primer
Posted on May 23, 2008
  • Perry Babin May 23, 2008
    I would guess that the power supply FETs have failed. That's generally the only part that sparks or smokes when an amp fails. Let me know if you have any other questions.
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
Jensen uv10 amp hook up
how to power on the amp on my flip out headunit
Feb 07, 2010 | Jensen Car Audio & Video
I am looking to buy a 1200 watt jensen 2 channel amp. what model is this? is there a jensen 1200, i have not seem it.
I would recommend you purchase a brand name 600watt RMS amp instead of a Jensen 1200 watt peak amp. Trust me you will notice the difference. Try a kicker, hifonics, MTX, audiobahn Autotech... Its not the watts its the quality of the watts..
Sep 12, 2009 | Car Audio & Video
Its stuck on protected. I recieved the amp for my birthday in 2000. It protected it self 90 days later. I needed an amp righr then so I went and bought a 600 watt jensen. I took the old one out of the...
whats the ohm rating of amp probally 4 what is the ohm rating for sub how many subs are you running how do you have them hooked up parallel or series is your wiring to amp right
Jul 06, 2009 | Car Audio & Video
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
400 watt jensen amp not hitting.
Not to be mean but jensens have never hit as far as i know
Jan 29, 2009 | Jensen LXA400 Car Audio Amplifier
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Sound comes on, goes away
it needs to be checked for faulty solders if you dont know how to do this take it to a tech
Jan 29, 2008 | Jensen XA2150 Car Audio Amplifier
VR 200 Watt amp
Disconnect the wire from the remote turn-on terminal of the amp and insulate it so that is can not make contact with anything.
With the wire disconnected, does the amp remain on?
Jan 03, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
Jensen JPA285 Car Audio Amplifier Logo
159 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
