Change the needle that is what will cause it to skip stitches
Here are some suggestions
the needle may be bent--roll on flat surface to see if it roll correctly
blunt or damaged at the tip
tension maybe to tight or loose
the needle timing may not be set properly
the needle bar height may not be correct
the looper & needle clearence may not be correct
