Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Is just air
How can i do if the compressor is not entering in my a/c, is not cool , just comes out air
  • Anonymous Jun 23, 2008
    The unit has been setting for 2 years- Whwn I turn it on only air comes out.
    Novelist:
    Champion:
  • 230 Answers
I am not sure I understand your question. But first try checking all the related breakers, fuses and receptacles. Then double check the thermostat is in the "auto" not "on" mode and that it is set lower than the room temperature.
If non of this works it seems as if there is a problem at the outside unit. You will need a licensed technician to help you out.
Posted on Jun 18, 2008
Car blowing hot air when on cold
First check to see if your A/C compressor clutch is cycling on / off. If it is then feel the line that's entering the vehicle, not the one going to the condenser (usually in front of the radiator). If the entering line is cold, then you either have a damper problem (the little door that open to allow the cool air in from the heat exchanger) or you need to set your air ducting to recirculate, not fresh. If the line entering the vehicle is not cold, you may have a mechanical problem with the compressor or a refrigerant leak. A refrigerant leak (or low charge would prevent the compressor from pumping and you wouldn't hear the clicking of the compressor clutch as it cycles on and off while cooling. This is a common thing in automobile A/c systems. Sometimes from hoses or lines vibrating and rubbing against something until it springs a leak, and it could be very tiny.
Aug 21, 2013 | Heating & Cooling
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
Dear, I have a question that when turn on the air conditioner, it's blowed out the hot air. How can i fix this problem to get it cool again? Thank you
You will need a service call to check for a leak in the coolant or possible bad compressor or compressor starter. If the compressor is coming on and no cool air then the coolant has leaked out and can no longer cool the unit and will need replaced by a licensed technician. If the compressor is not coming on but gets very hot then the compressor is bad, and if it is not coming on and not hot then the starter condenser is bad.
Jun 25, 2011 | Heating & Cooling
Unit blows cool air out but doesn't cool room off. the compressor is not coming on. had freon checked ok
I have a question, how was the freon checked if the compressor is not coming on. If the compressor is not coming on, make sure it is received the proper voltage, if it has a capacitor make sure the capacitor is good. Also, how clean are the coils on the unit?
Apr 22, 2011 | Frigidaire FAS256R2A Thru-Wall/Window Air...
Blower fan running but compressor not coming in.What could be the problem
To get proper cold air set temp 23 degree and mode"cool". If still no cooling, check power in out door unit. If power on, check compressor is working. If not working call repairman to find out exact problem, as there are many reasons for compressor not operating. Thanks.
Jan 01, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
My lg a/c only blows air with no cooling what is
possible a tstat problem or compressor is not coming on...put your ear by the ac unit...if you hear a buzzing noise ,then shuts off,humming...compressor not coming on...
May 09, 2010 | LG LB1200ER Air Conditioner
Thermostat slow to turn AC compressor on. fan comes on but takes 5 min. before compressor comes on
Most a/c's have a 5 minute delay before the compressor turns on and they will do the same when changing from cooling or heating to cooling.
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
No cool air conditioning, if it enters the compressor to work well, but fans do not cool the air and apparently there are no leaks, that may be?
check heater flap cable ajustment to make sure flap is shutting off so no air from heater core is going into evaporator common problem.
cable moves or comes out of retainer clip remove glove box to see
Jul 13, 2009 | 1991 Isuzu Rodeo
The unit has quit cooling. The compressor does not seem to be coming on.
check thermostat contacts, possibly not sending signal to pick up
Jun 02, 2009 | Amana PTH153B35AE Air Conditioner
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
