Question about Motorola Mobility 98627 Wireless Headset
Motorola blue tooth h350
Would like to know if you have the code to sync this blue tooth to a new phone?
Posted on Aug 09, 2008
What is my pass key for H350
motorola uses two pin pairing codes for their blue tooth devices they are as follows,0000,or 1234 there are two other codes for blue tooth devices as well they are as follows 1111,or 9999 glad to be of assistance.
Feb 26, 2011 | Motorola Mobility H350 Wireless Headset
What do I push on my h350 to pair it with my cell phone?
First make your cellphone discoverable via blue tooth.
Make sure you headset is charged.
Press and hold the call button of your headset and hold it until you see a steady blue light.Now your cellphone should pick up your device. Select it and it will ask you for a pass code. Refer to the user manual of your headset for the pass code. Generally which is 0000 on most occasion.
Mar 23, 2010 | Motorola Mobility H350 Wireless Headset
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Maual for Motorola H350 bluetooth headset
Hi - You can download the manual from the link underlined in blue below:
Motorola H350
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 18, 2008 | Motorola Mobility H350 Wireless Headset
Motorola blue tooth pin code
Yes there is a universal code. It is 0000. That is four zeros.
Hope this helps :)
Oct 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility 98627 Wireless Headset Logo
54 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
