Question about Bissell 1770 Quicksteamer II Upright Vacuum
Motor problem machine is smoking/burning smell coming from the bottom of the machine. Motor still turns but doesn't make much sound; and soulution won't squirt. The model # is 1970
  • Anonymous Nov 24, 2008
    I have the same problem. My machine pumps water out onto carpet, but nothing is sucked back in. It makes the right noise, but then it started smoking. I had to throw mine away as well.
I had to throw the machine away before it burned my house down. There is no way to fix it; had to replace it.
Posted on May 23, 2008
Sewing machine Guru needed ;) Elna Grasshopper (new to me) circa 1950 The light works, but there was no hummm when knee pedal engaged. I have the motor out, and it is very stiff to turn. I'm...
I just purchased a fairly tidy Elna 'Grasshopper' sewing machine (1951) with the same leaking capacitor problem. I carefully removed the capacitor for examination. It is actually three capacitors in one - no chance of a direct modern replacement, but anyone with those three capacitors, a couple bits of insulated wire, and a small soldering iron should be able to shoehorn them into the same space. There is a circuit diagram printed on the side of the original capacitor, showing one 0,2 micro-Farad capacitor between the two mains power buses (the two wires from the top of the original capacitor which are soldered to the top of the two outer brass bars where all the wires attach), and following on from each of those a 0,0025 micro-Farad capacitor (so, two of those), the other side of both of those joined together and going to the chassis - representing the one cable from bottom of the original capacitor, which is screwed down. Easier than it sounds - I just have to find those capacitors. They must be NON-polarised capacitors, rated for 250 Volts, and I plan to use radial (rather than axial) style, aluminium type ones - very common. From what I can gather, I believe they are needed for that lovely little motor to run properly - to have torque ('oomph') at start-up.
As to the motor not wanting to turn... difficult to say from a distance. Could it be that the 'brushes' are sticking - or even worn out? There are two, top and bottom, that ride on the commutator - the ring of bronze-colored squares on one end of the motor, behind the wiring. They are made of carbon, are what power the motor, and are held with hidden springs. With much use they wear down, but I would not expect them to be completely gone. The upper one is easiest to reach - there is a brass screw above it - careful the spring doesn't get away. Only other thing would be fouling of the bushings that allow the axis of the motor to turn. A little penetrating oil could help there. The motor should turn very freely.
May 16, 2011 | Vacuums
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Was hoovering when my DC04 made a funny high pitched noise then a whirring noise, this was accompanied by a smell of burning and a puff of smoke! Almost sounds like it might be a clutch slipping, is this...
OK... the DC04 doesn't have a clutch. My best guess is that the belt that drives the brush roll has broken. The smell of burning and smoke puff were probably caused by the motor suddenly speeding up when freed of its burden of driving the brush roll. For illustrated guidance on checking (and if necessary changing) the belt, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC04 Belt Change Guide".
I hope this helps. If so, please remember to rate this response. If not, please post a reply and I'll try again. Good luck!
Feb 05, 2010 | Vacuums
Burning smell
The bottom doesn't come apart. you have to remove the top cover to get to any components. But if you have a burning smell, then it is probably ther motor and would have to be replaced. Motors cost anywhere from $70 to $90.
Jun 14, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Smoke/motor?
I don't know in Nev. call Hoover's 800 number and they will tell you, the number is on the metal tag. But if it is the motor smoking, a motor will run you $85 to $95, plus labor, $40 to $50. But if this an electrical smell, then suspect the motor. But if it is a rbber smell, then maybe you have a belt that is slipping badly, replace the belt.
May 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
264 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
