Question about RCA F38310 38" TV
My RCA F38310 doesn't seem to want to turn on all the way.
When I turn the power on, the set starts to come on then just stops & starts. I'll here the clicking of the tube & fans start & stop every few seconds. The power light stays on, but the rest won't. I was told that the problem might be the video amplifier board (by a repairman who didn't even open up the TV), but I've VERY unlucky in finding the part. Does anyone know where I can find the part or the websites to find it. Or, does anyone think the repair guy is full of it, and there is actually something else wrong with my set?
  • 1 more comment
  • niceguyocho
    niceguyocho Jul 29, 2008
    unplugging it for awhile still hasn't changed the problem :(
  • guevon Jan 17, 2009
    After 8 years of constant use, I'm having exactly the same problem. Unplugging it doesn't fix the problem. This is not a good time for me to buy a new HDTV so wondering if it is cheaper to fix it than getting a new one with comparable specs.
  • Anonymous Apr 02, 2009
    Sometimes mine will sort of go into a "loop" powering off/on similar to what you describe. Physically unplugging the set for a few minutes, plugging back in solves my issue. But not everytime.
Posted on Jul 15, 2008
LED blinking red
A red blinking light usually means the system is in standby mode.when you press power or TV it should turn on and be green. Try manually turning set on or off.
Jan 04, 2011 | RCA F38310 38" TV
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
I have an RCA 38-inch HDTV (F38310). While watching, it began scanning through all the options (vcr1, vcr2, directv, etc.). The volume bar also popped up and the sound was turned down. I couldn't control...
apparently this is a common fault with this model, contact the retailerfor a refund or repair. pitiful power supply, poor-quality electronics, etc.
Jul 31, 2009 | RCA Televison & Video
No picture/no sound. fan working
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
May 10, 2009 | RCA F38310 38" TV
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
More info on my RCA F38310 38" TV
Thanks for the reply.
Go to this site and browse through their stock of parts for this TV model. You can give them a call as well if you do not see what you are looking for.
Good Luck.
Apr 13, 2008 | RCA F38310 38" TV
Bad diode.
It seems that the number provided "CR14710" is the number near the part on the board. Are you sure this is the part number or rather, is it the part's schematic reference? I interpret "CR14710" as Control Rectifier 14710 that can be found on a schematic. I say this because you also said "a badly burned diode" and usually the part number becomes illegible from this.
Dec 11, 2007 | RCA F38310 38" TV
Rca..model f38310
My set just recently went throgh the same problem. I found a bad connection on the power board and a burned diode as well. I repaired the conneciton but have had no luck getting the specs on the burned diode. RCA has been no help.
As for cost of repair, on serviceman quoted $50 just to come take a look.
Dec 09, 2007 | RCA F38310 38" TV
Tv antenna
Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 21, 2007 | RCA F38310 38" TV
RCA F38310 38" TV Logo
175 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
