Question about Toshiba Tecra M2 Notebook
Drfting cursor The cursor will from time to time drift off to the top right corner or the lower left one, and will not come out, even with firm appilication of pressure on the accupoint. Other times it will move grudgingly but not hold steady. Then it will suddenly behave normally for a while. Using the touch pad is then OK. The same problem occurs with a USB mouse. I tried placing the cursor on the minimize button, top right, and touching the center of the touchpad; this seemed at first to work, but soon the drifting resumed. Any solutions would help.
  • Spencer Campbell
    Spencer Campbell Nov 02, 2008
    My cursor has suddenly become possessed! Like the previous complaint it drifts on it's own then can not be found then acts normally - for a short while before going nutso again. Help!!!!
  • greenwoodl Apr 09, 2009
    my cursor does the EXACT same thing
    Scholar:
  • 187 Answers
This is a well known occurance with laptops and is not something you can fix. Occasionally the manufacturer will release a patch to try and help, but this is very rare.
Posted on May 26, 2008
2 Suggested Answers
Roshan89
  • 271 Answers
SOURCE: drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
How do I change the time & date on my computer.
Place arrow (cursor) over time and date in lower right corner, right-click, select "adjust date/time" in menu and left click.
Oct 10, 2014 | Watches
Where do I turn off my laptop
Power button is top left corner of keyboard above the "Esc" key.
If you are trying to shutdown from Windows 8, follow these steps:
1. Mouse over the little gadget in the lower right corner of the screen. (You can also move your mouse cursor to the upper left corner; same result. Or, you can press Windows-C on your keyboard.)
2. In the slide-out menu (known as the Charms Bar) that appears, click Settings.
3. Click the Power button, and then click your desired action: Sleep, Shut down, or Update and restart.
Mar 07, 2014 | Dell Computers & Internet
What's an Air Hockey gameplay?
The games play as described by USAA:
  • The mallet is gripped behind the knob using one's fingertips, not on top of it. This allows more wrist action and helps the player to move the mallet around the table faster.
  • For basic defense, the mallet is kept centered at least 8 inches out from the goal. In this position, very slight movements to the left and right will block virtually all straight shots. To block bank shots, one pulls back quickly to the corners of the goal. This is known as the "triangle defense".
  • Shots are often hit out of "drifts", where the puck travels in set patterns designed to throw off the opponent's expectations and timing. The most popular drifts are the "center", "diamond", "diagonal", and "L".
  • Shots are often organized into "combos", meaning groups of shots which are hit with the same apparent delivery but opposite directions, caused by hitting the puck at slightly different locations on the mallet. For example, a transverse motion of the right arm can lead to a "cut shot" to the left corner of the opponent's goal or a "right wall under" (bank off the right wall, into the right corner of the opponent's goal).
Jul 25, 2012 | Sport & Outdoor - Others
The cursor will from time to time drift off to the top right corner or the lower left one, and will not come out, even with firm appilication of pressure on the accupoint. Other times it will move...
Your touchpad is going. :( Outside of replacing it, you'll probably want to disable it and use an external wireless mouse. There are models now that have a tiny receiver than can be left in the USB port when the laptop is stored away. Not a fix, but a workaround.
Jul 01, 2009 | Toshiba Tecra M2 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
When browsing page goes very small in top left hand corner
this happen when you shrink the browser page and close it without maximized it.
open the browser page, click and drag the page to the left top corner of the screen (top left corner of the browser page is at the top left corner of the screen).
move the mouse to the right lower corner of the browser (the arrow will change to 4 direction arrow). click, hold and drag the corner to the lower corner of the screen.
close the browser.
the browser page should be full screen when you reopen the page.
Dec 30, 2008 | Microsoft Windows Vista Ultimate Edition
Drifting cursor
May 26, 2008 | Toshiba Tecra M2 Notebook
Cursor control at the right side of the tablet is out of control
u gotta call me and **** my left nut U ******* COKC MUNCHER
Dec 05, 2007 | Ace Hardware Flair II GT-504 (GT504)
Toshiba Tecra M2 Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
