Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Blinking red light
If the light is red does that mean that the ice storage is full? if so i think that's my problem. the ice maker isn't making ice. no water going into the tray,etc. but the water is coming out of the door.
  • Anonymous Aug 17, 2008
    No ice is being made.
    Sergeant:
  • 409 Answers
the red light means that you have blockage somewhere in the dispensing of the ice.
check the ice paddle for any breakage and the inside of the door and water line for any frost build-up.
if everything checks out okay, it will be the water valve itself or the water solenoid.
Posted on Sep 17, 2008
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
No ice production what does the red light mean
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
The red light is a sensor that check the ice level... make sure that nothing is blocking the beam so that it thinks the bin is full...
heatman101
Oct 27, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Not making ice!
Try removing it and let the ice thaw. The mechanism for the rake to push out the ice can freeze up.
Apr 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
The ICE Maker just Stooped making Ice ? but the water is ok I still get the chilled cold water. There is a Stupid Red Light Blinking I think Twice then stops, Is that a code? this is just 3 years Old in a...
I don't know about the dust bunnies on your coils, sounds like you would have you use a vaccum attacthment or even a compressed air nozzel, but as far as your ice maker goes try totaly turning off the fridge and compleatly 100% defrosting it.
Jul 26, 2009 | KitchenAid Superba KFRS361TSS Stainless...
Kenmore 106.56542400 No ice, red lite blinking
Many people claim that raising the freezer temperature and using a hair dryer to defrost the ice maker will solve the problem. As for the blinking light I believe that is part of the ice maker sensor to tell if ice storage is full or not. Here is a link to the troubleshooting forum. Thanks, Sea Breeze
http://www.thriftyfun.com/tf50663056.tip.html
Mar 19, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
