Question about Kodak Cameras
When my camera is fully charged, all of the lights on the docking port are lit. Now, only one light, the one to the right of the Kodak button is lit. I have a new battery in my camera. What could be the problem (other than the user, that is)
I had really intended to get the Kodak help center and somehow got you by mistake. Maybe I will use you another time. Thanks.
Posted on May 23, 2008
As soon as I turn it on, it shuts back off
Kodak offered no help with this problem and for my camera more than five years old no repair option was available. However, after thinking about this problem a solution was found. Perfectly charged old batteries and new batteries fully charged did not correct the problem. Here is what worked for me: With fully charged battery installed, place closed camera on EasyShare-One camera dock. With the the green light flashing, simultaneously depress both the power on/off button and the shutter button. With both these buttons held down, toggle the capture view switch from an intial down position to up, and then down position.Now release both the power on/off button and the shutter button simultaneously. This whole process takes about 20 seconds. Let the camera remain on the dock until the green light stops flashing. Remove the camera from the dock, open the camera back as usual and the screen will present you with date/time setup. Enter the date and time as required, hit the 'done' icon with the camera pen and the camera will now function normally. Why this works is speculative. However, the idea behind this method is to force a 'reboot' to factory settings by maximising conflicting electronic input signals.
Dr Barry T Rubin
Aug 13, 2010 | Kodak EasyShare One Digital Camera
Kodak C340 I installed new batteries and docked it over night and the camera still dose not turn on
with new batterys you may find if quicker to charge them in a battery charger and not in the camera,,,the camera charger is for "topping up" the batterys realy not fully recharging them its so you can leave the camera on its docking port and it will have fully charged batterys in it when you wont to use it,, to fully charge a new set of batterys it could take days,,,,so overnight is to short a charge to recharge them,,,leave the camera on its docking station for a fuw days at least, or use a home charger for your type of battery ie:AAA or AA, both take 16 hours to recharg fully
Feb 16, 2010 | Cameras
Kodak C613 camera dock won't charge my camera. The green light won't light up, Help
What batteries you use?
The camera docks only charge the kodak battery pack KAA2HR (you can buy this pack at the kodak website) or Kodak Li-Ionen batteries but they don't work in Your camera. So buy a battery pack KAA2HR from kodak and the dock will charge it ;-)
Oct 07, 2009 | Kodak Easyshare Z8612 IS Digital Camera
My Kodak G600 printer dock will not recharge my Ni-MH batteries.
you're right. You only can charge the Orginal KAA2HR batterypack of kodak in the cameras.
Aug 26, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Apr 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Jan 30, 2009 | Kodak EasyShare Z760 Digital Camera
My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Jan 25, 2009 | Kodak EasyShare DX4530 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
My Kodak V1003 will not charge.
  1. Make sure the Ni-MH rechargeable battery is in the camera.
  2. Place your camera on the printer dock.
  3. Press and hold the Battery charging lights/Refresh button, until the Battery charging lights begin flashing green (approximately 5 seconds).
Aug 05, 2008 | Kodak Cameras
Cameras Logo
19 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
