Question about RCA Televison & Video
On/off switch on colortrac plus tv stopped working. Won't turn on.
  • RCA Master
  • 8,617 Answers
Have you tried turning the set on by remote ? Whats the model number of your RCA TV?
Posted on May 22, 2008
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Kia sorrento wipers won't stop
I had the wipers won't shut off, or turned on by themselves on my 2005 Kia Sorento. It about drove me nuts. I came across my solution by pressing every button I could find, eventually finding out what the mystery button to the right of the hazard button on the dash was for. (It's to defrost the front wipers by the way) You can investigate further if you'd like but it's not necessary if this works for you.
I simply pressed the button on, waited a moment and turned it back off. It stopped the wipers. They came back on about three more times over next few days and I repeated the process each time. It's been about three weeks since the last time I did it and I haven't had any more problems. This sound crazy or quirky I know and I don't pretend to understand it, but it's working for me. It beats the heck out of paying over $300 dollars plus labour for a new wiper switch . I priced them. Good luck.
Jul 17, 2012 | Kia Cars & Trucks
I want colortrac smartlf 4080 driver WIN 7 Problem
Hi
Does your operating system 32 bit or 64 Bit ?
May 10, 2011 | Computers & Internet
I need a copy of the schematics for my 9-inch color TV so my husband can fix it.
Well you need to look at the manufacture for this as we do not have diagrams here for TV as there old the newer ones I can find but the older oneswe do not have copies anymore due to the digital conversion.
May 25, 2009 | Televison & Video
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
RCA Colortrac 2000--can't hook up video game machine.
Be sure the hookups are in the input #1 row. Then tune to channel 91. Dont know if all tvs have to be on channel 91 but its the only one that works on mine when I hook up my xbox 360.
Dec 27, 2007 | Televison & Video
Keystone colortrac 2000
Sounds like tuner need resoldering
Sep 09, 2007 | Televison & Video
Guide Plus Demo
I have serviced lots of these, and as far as I know the CTC203 chassis has nothing like this, nor did anything made by Thomson before or since, so I am mystified. Adjustments are made with the remote or the front panel buttons using software and there are no "pins," test connectors, switches, or anything similar present on it. Usually the Guide Plus stops working entirely (which is nice for most users, as it is just an annoyance). Now if you unplug your TV for long enough for its microprocessor to reset, it will start with the Guide Plus screen. This is by design and can't be stopped without modification. Corruption of the set's internal program causing something strange like this is possible, but unlikely. (It was a problem on earlier models). Leave your TV plugged in and see if this problem goes away. If this is not the cause, you will have to take it in for service. Any demo modes can be turned on or off with the remote or the buttons on the set.
Feb 24, 2007 | RCA F27649 27" TV
Televison & Video Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
