Question about SanDisk Sansa e270 MP3 Player
Songs on my Sansa
I have tried re-formatting my Sansa when it has not been working, but even that doesn't fix my problems with songs on my Sansa. Many songs register as Already on Device, and when i try to delete songs, they no longer appear on the computer, but they're still on my MP3 player. How can I fix this?
  • Anonymous May 26, 2008
    i put songs on my mp3 player but when i unplug it there are no songs on it
  • Anonymous Apr 18, 2009
    i dont no how to get to my songs
  • 8,596 Answers
When using Windows Media Player 11 to delete, you have to look carefully at the folders on the left hand side of the window in the "Library" Tab - the first set of folders are the songs stored on your computer only. If your mp3 player is plugged into the computer and the computer recognizes that it is plugged in, you will see an icon of your Mp3 player in the list of items in the library tab. You must double-click that icon of your mp3 player and bring up your music files that way. Delete the files from there, and it will usually (not always) ask you "this will permanently delete files from your device" blah blah blah. You're there.
If it is physically preventing you from deleting songs on your player, then you will have to use another method to wipe the songs clean:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Posted on May 28, 2008
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Sansa c250 troubleshooting
The Bearshare songs have either a Green or Gold disc next to them. If you don't have a current, paid subscription, one set of them won't work. If your Bearshare subscription is up to date, connect the mp3 player to the computer and have Bearshare update the licenses on the songs. Also, some Bearshare songs have fixed-term licenses - your playing rights from the mp3 player expire after a certain amount of time. If you choose songs that are only in mp3 format (i.e.: not bearshare, napster, etc.)
-Tha Mp3 doctor
Nov 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Sansa displays "no song"
Could Be An Unrecognisable Format
Try Download Them In MP3 Format
Sep 30, 2008 | SanDisk Sansa MP3 Player
Removing songs from sansa e250
Try To Format The Player, Sorry I dont have Mac
Jun 15, 2008 | SanDisk Sansa e250 MP3 Player
Does not support few songs format
Make sure the songs are unlicensed
May 10, 2008 | SanDisk Sansa e250 MP3 Player
PROBLEME OF MEMORY.
My Sandisk Sansa m240 lost all the songs and then I could not delete them. I was able to laod up new songs, but there was no spare memory. I was able to fix this issue by re-formating.
Using windows explorer right click on the "Sandisk sansa M240" and click "format".
Now working OK.
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
Songs are not being show (not getting detected) in the music list
k i had the same problem twice,
the first time i couldnt fix it because i ended up getting a device read error when i tried to acces it in my computer, but i think whatever caused that was different than the second time.
this time my device retained all the songs origionally on it but wouldnt reckognize any new songs. In addition to that, when i deleted all the songs off the player and only put a couple back on the player didnt register those either. so it would seem to me that it is a problem with the device's database refreshing algorithim...although thats just a guess.
neways...to fix it i copied all the data & folders off the sansa (including the .txt and .sdk files) and stored them on my desktop. After that I tried the e200 firmware upgrader available at sandisk.com
After messing around for 2 hours trying to figure out what was going on i deleted all my music, videos, recordings and pictures off the device and proceeded to format it in msc mode.
after the format was complete, i re-copied the data i had backedup on my desktop and pasted it back onto the sansa.
it seems to have worked...but then again i still don't know what caused the problem so it may not work for you. (i think it may have been something to do with one of my music files since both instances happened after i uploaded the same 5 songs onto the player)
also, i had numerous virtual folders & files that had conflicting sizes and would not open when i clicked on them (windows says they had +4GB sizes but properties says 0B also when clicked i get a file not found error).
hope this helps.
Nov 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
115 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
