Question about RCA L37WD12 37 in. LCD HDTV
Picture to big, half the screen is cut off
I can't figure out how to get the picture smaller. I think it called panning? The screen is set in some kind of zoom mode half the screen is cut off cause its so big. How to change?
First off did you get the right remote. I had this same problem and was not able to fix it because I had the wrong remote. You should have DSP mode on the remote near the select / ok button in the middle of the remote. The left and right arrows allow you to move through the different picture zoom / format settings. You will need to set yours to the 16/9 format to get it correct. I use the
RCA Universal Remote 5717P. Works great.
Thanks.
Posted on Jun 01, 2008
  • Sammy
    Sammy Jan 09, 2014
    My big screen tv RCA only half the screen works what would cause that
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
The picture is too big.
on remote go to menu there should be a way to set up picture side it will say zoom and so on
Apr 17, 2012 | Sylvania LC-225SL9 22 in. LCD TV
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
Jul 09, 2011 | LG 42PC3D 42 in. Plasma Television
I have an lg tv and picture is to big....cuts the
If you are tuning from cable or satellite you need to change the settings in the picture menu look for options like "stretch" "autofit" etc. cycle through until desired picture is displayed, turn off widescreen setting if you can find it check the manual for options regarding this. If you have it attached to a computer you will need to change the resolution to something smaller like 1366X768 which is the standard 720p resolution for the smaller tv's If there is still a problem it may be
May 21, 2010 | LG 32LG30 32 in. LCD HDTV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Picture too big for screen
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
Picture is vertically too big the heads dont fit the screen?
This answer is generic because I do not know the particular model:
You should call the tech support for your set. This may be a fault in the way the address processing is being performed for the display. Sometimes, depending on the model, the service rep can fix this by re-loading the firmware for the set's operation. I have seen failures in the main drive processor for the screen cause this. The solution was to change the board.
Jerry G.
Jan 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
RCA L37WD12 37 in. LCD HDTV Logo
350 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
