Question about HP DeskJet 9800 InkJet Printer
Printing Avery 5202 lables to my HP Color LaserJet 3600 Printer
I have a HP Color LaserJet 3600 Printer and I am trying to print Avery 5202 lable (4X6) from the manual feeder and its not alligining the print in the right place.
I have Avery 5202 word templet using which I am printing the label
SOURCE: Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Posted on Dec 19, 2007
SOURCE: label printing
If you don't change your settings this is the problem of your printer hardware. Just open the printer & you can see a long rod & some devices fitted in the both end of the printing area it called carrage Assembly. there you can see two small clip it is the device of mergine settings change it as you like. If it won't work for a single time try to do this in many combination.
Posted on Feb 13, 2008
  • 149 Answers
SOURCE: Problem printing Pendaflex file tab labels from 4600dn
Make sure the settings are properly set within the program and printer.
Posted on Jul 18, 2008
  • 5568 Answers
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
Posted on Aug 26, 2008
  • 14 Answers
SOURCE: Easy peel Labels stuck to rollers cant print
On which roller are these labels stuck? On the drum roller? or at the back in the fuser.
If it is the drum you can always try with a soft cloth and some denatured alcohol.
Soak the label first with alcohol to loosen the glue, then remove the label and take a new
clean cloth to remove the glue with alcohol. Notice that the drum is light sensitive, don't expose it to bright light for too long.
If it is in the fuser you'll have a bigger problem. You'll have to remove the fuser first to access the rollers (caution, let it cool down first, fusers get really hot)
You need to remove the duplex unit (if available) or duplex cover and the 2 small side covers.
In the left and right you will notice 2 screws that tighten the fuser. Remove these screws as well as the dataconnector on the right and the fuser lamp power supply to the left.
Now you can easily slide the fuser out.
The tricky part is to open the fuser up to access both heat- and pressure-roller to clean them in the same way you should clean the drum unit. Normally you can open the top cap of the fuser loosening 2 screws don't know exactly which ones
When this is done you can reassemble the printer and all should work fine.
If you intend to open up the fuser, let me know, i'll get you the detailed information for that.
when you use lables that are suitable for laserprinters always use the manual front feed and open the rear cover, that way the paper does not get folded, it just runs flat right through the printer.
Posted on Dec 06, 2008
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
I have a BROTHER MFC-8480DN all in one printer which I just purchased. My avery lables do not work right as the first 2 rows are okay and then the text does not fit right on the following labels. I use it...
Lables are slick some time the feed rollers will slide on them. Try to find lables that are course with no shine on them . The rubber that the tires are made of is of poor quality. Just dont have the grip . Hope this helps
Aug 12, 2010 | Brother Office Equipment & Supplies
Printing from the wrong trey
Hi, your printer tray 1 is not detected by controler, so you need do:
1) change other tray box instead if you have same one, easy fix it
2) check tray 1 box back side, there is a sensor (optical sensor it does not work), you need find out a white lable stick around there, if the lable is not white enough, the optical sensor does not detecting tray 1.
hope help you fix it and answer your question any time, please rating me thanks
May 14, 2009 | HP LaserJet 4700 Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Jul 01, 2008 | HP LaserJet 4600dn Color Printer
Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Feb 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
HP DeskJet 9800 InkJet Printer Logo
319 people viewed this question
Ben Johnson
