Sharp xg-h400u projector Lamp timer reset.
We replaced the bulb but forgot to reset the lamp timer. The timer needs a hard reset now and can not find the steps to take to do it. Sharp will not help and the service center i took it to can not find the instructions to do it. Please help. This projector is used for a non-profit org. nad we dont have the funds to send it to another service center.
Thank you
Travis
  • 1 more comment
  • MESTERLING May 27, 2008
    I replaced the bulb but the lamp timer will not reset. The timer needs a hard reset now and I can not find the steps to take to do it. Sharp will not help and the service center I took it to can not find the instructions to do it. Please help.
    Thank you
    Michael
  • visions1 Jan 06, 2009
    I have a XG-H400U that turns itself back off immediately after turning on.
    I can see the lamp strike just before it goes back off.
    Any suggestions?
  • davron Apr 14, 2009
    I have the same problem but do not have a remote and the post regarding page 52 is not for a XG-H400U.  I would really appreciate help.  Does anyone have a manual for this model???
    Thanks in advance.
Plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
Posted on Jun 07, 2008
  • hardradio Jun 07, 2008
    Map should read lamp, I need more coffee :)
Reset timer
Posted on Oct 01, 2010
With the projector in standby, press rest, the left, then right, then enter on the remote, all within 5 seconds.
Posted on Jan 01, 2009
Hello Friends,
I replaced my lamp and as I was trying to reset the lamp time using instructions, the power shut down automatically and now it will not turn on. Any suggestions will be highly appreciated.
Thanks,
Deepak
Posted on Sep 04, 2008
Thanks easy fix
Posted on Aug 29, 2008
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
Cannot reset lamp timer as will not project. Replaced the lamp in my 3m X50, bulb came right on. I had to shut it down before reseting the lamp timer. Now will not light up so that I can navigate the...
It does not sound like resetting the lamp timer is what is keeping the projector from throwing an image. Try walking through the steps of the installation backwards to remove the bulb completely. Then reinstall the bulb again from scratch making sure everything is seated properly. If it powers up again just remember to set the clock back on the bulb.
Mar 03, 2011 | 3M X50 Multimedia Projector
I have a Sharp XR-10X-XL projector, i have replaced the bulb but it still will not go on. The Stand by light and the bulb light are both on constant red, I have checked both the heat sensor and the fuse on...
Have a nice day!
Jerry
Lampdeng Limited
Dec 13, 2010 | Sharp (AN-XR10LP) Projector Lamp for XR10X
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
Aug 07, 2010 | Sharp XR10XL DLP Projector
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
How to reset the timer on a sharp BQCXVZ1001 when changing bulb
Jan 05, 2009 | Sharp BQCXVZ100001 Projector Lamp for...
Sharp TV Flashing Codes
did you purchase just a new bulb? or did you buy the bulb with the cage included?
Oct 21, 2008 | Sharp 56DR650 Television
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
3,118 people viewed this question
jasbo
jasbo
