Question about iiyama E431S-B 17" LCD Monitor
Iiyama E431S-B 17" LCD... Problem:
The led light comes on blue. and the screen will show a perfect picture for about 3 seconds, then goes blank, but if i pull the cable from the computer out and then back in it does the same again. Can you help?
  • 1 more comment
  • Anonymous Oct 27, 2008
    I've got exactly the same problem. I think I'm just going to go for a new one off eBay rather than go through the rigamarole of finding the parts. Unless someone has any idea where to get the power supply things from?
  • Gramler Mar 12, 2009
    mmm... I doubt it is the power supply. I have same behaviour, but have KVI switch... eveyr time I swithc between machines, display comes back..for abot 3 seconds then dispears. Also in Unix, if swtich between Deskptop and command line modes (ie forcing modes changes) it comes back.... I think it is related to the motnitirs ability to detec incoming signal. If no signal is detected it show a message "no signal" then blanks display after a few second.
    At the moment the problem is interremittent... repeated switch evertually makes it stay on.
    Perplexing...
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    This happens while you are booting up? Do you hear a bios loaded beep?
    Worldvet
WHAT DOES THIS CAPACITORS LOOK LIKE, SIZE? THERES SOME BLACK AND SOME PURPLE, IF IVE GOT THE RIGHT ONE. IS THERE A No. NEXT TO THEM E.G C924? WHERE CAN I BUY THEM FROM?
THANKS FROM Steffan
Posted on Oct 13, 2008
  • 42 Answers
Power supply is defective, replace all secundary capacitors.
greetings Drikus
Posted on Oct 12, 2008
  • brexan Jun 01, 2011
    Replace capacitor C922 1000uf/16V on the power supply print.
I can't get any sound from the monitor the menu doesn't seem to switch the sound on
Did you connect an audio-cable from the "line-out" socket on your computer's sound-card to the "line-in" socket on the back of the monitor?
Nov 05, 2010 | iiyama ProLite E431S 17" LCD Monitor
My iiyama e431s monitor pwers on and off every 2 secs. the picure is fine when the power light is on but the light and picure switch off regularly every 2 secs.
1) Go to Control Panel (Located on the start menu).
2) Then double click on Power Options.
3) The Power Options Properties window shall now open.
4) You will see a section called Settings for x power scheme, the x depends on which power scheme is enabled.
5) Click on the down arrow to the right of Turn off monitor: And set this to Never.
This should stop you monitor from powering off every 2 secs. If you need any further help just add a comment.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 02, 2010 | iiyama E431S-B 17" LCD Monitor
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
Do I need a software Cd for instalation ?
No, your Operating System will choose the optimum settings.
Jun 28, 2010 | iiyama E431S-W1S (White) 17" LCD Monitor
Power on, not picture, blue indicator keeps coming on, going off plus a click at each change. Ghost flicker on screen but not enough to distinguish a picture. It was working perfectly for the last 5 years...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | iiyama E431S-B 17" LCD Monitor
Iiyama Prolite E431S turns itself on and off
i think your monitor lose a power connection
Aug 31, 2009 | iiyama E431S-B 17" LCD Monitor
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
ProLite E431S - comes on dim for a few seconds - then off!
Probably the power supply is defective.
Most probably the electrolytic capacitors in the secundary circuit heve become bigger then they used to be.
Replace them all...
greetings Drikus
Jun 03, 2008 | iiyama E431S-B 17" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
iiyama E431S-B 17" LCD Monitor Logo
606 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
